Siril Refuses to apply PCC Siril Team Siril · Alien_Enthusiast · ... · 10 · 229 · 2
Alien_Enthusiast 2.86
What do I do?
Siril is not willing to apply PCC :-(
After applying, everything becomes black
Here is the console;
This might help https://www.google.com/search?q=nan+definition&sca_esv=986cfd32cb66a37f&sxsrf=ADLYWIL1tqx__pS5lZE_n2ZykAuTUFPTgw%3A1717116453615&ei=JR5ZZoqhJeO6kPIPwpGnuAY&oq=nan+def&gs_lp=Egxnd3Mtd2l6LXNlcnAiB25hbiBkZWYqAggAMhAQABiABBiRAhiKBRhGGPkBMgsQABiABBiRAhiKBTIFEAAYgAQyBRAAGIAEMgUQABiABDIFEAAYgAQyBRAAGIAEMgUQABiABDIGEAAYFhgeMgYQABgWGB4yKhAAGIAEGJECGIoFGEYY-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&sclient=gws-wiz-serp
thank you
did you get your problem fixed though?
thank you
Nope
pretty sure someone would help you
someone plz help this guy
nvm solved it
It just worked
good!
ejsengineer 2.39
FWIW, I've got this error before and it was caused by too many of the stars being saturated. I ran the desaturate stars command under star processing and it solved the issue.
CS!
TiffsAndAstro 1.81
Alien_Enthusiast:
nvm solved it
It just worked
if you drizzle you might have to play with the Fl value so the pixel scale matches your actual pixel scale.
It can be a pita sometimes.
gaolsen 0.00
Ethan Sweet:
CS!
Just chiming in for others that find this thread. Desaturating the stars fixed it for me also!
