Help choosing a camera for my Rasa 11 Celestron RASA 11" · CMStars · ... · 24 · 745 · 0
CMStars 0.00
I’m brand new!  Bought a Rasa 11, focus motor, starsense auto align and sky portal.  A couple months in and no exposures yet.  What a learning curve… filled with frustration after frustration!  Can’t tell you how many videos and articles I’ve read to date, but still struggling just to get the components to actually work with the software.  Anyways…
I would like to purchase a dedicated DSC and am overwhelmed by the choices.   At this point I am considering going with a ZWO color camera to make it easier to grow into the hobby, but I don’t want to be disappointed with results.  I would greatly appreciate any recommendations that will be a good fit for my Rasa.
I am also planning to purchase a 2nd telescope such as the 8” Edge HD - this will be mainly for instant viewing and traveling, although it would be nice to get some deep sky images as well.  Any suggestions on equipment would be greatly appreciated.
Thanks in advance!!
smccully 0.00
RASA 11 is a large imaging circle, either a QHY or ZWO would be a great choice. I  would go with the largest sensor you are comfortable with purchasing. The IMX455 is a full frame sensor that is a good choice for instance.
dmsummers 6.80
I wouldn't be so quick to jump to the obvious wide field answer.   You need to ask yourself what you are interested in imaging, and then leverage to get there as best possible.   There are multiple possible use cases for the RASA with significantly different results.   Wide field is obvious, but have you considered / rejected narrow field?    The RASA combined with an ASI183 (for example) would give you a small field with small pixels, but allow for very nice resolution images of galaxies and smaller targets (but not so much for the smallest of planetary nebula).    There's quite a bit of joy in imaging at f/2.2 in OSC.   It's extremely convenient and low-hassle.   If you're in dark skies, this is a great choice.   If you're in the city, you have other issues (filters, etc.).
In my case, I have a RASA11 with an ASI183mcPro OSC, and I use it in Bortle 1 skies to to do acceptable work on galaxies and nebula in the ~1 degree field range.   If you go wider field to take advantage of a ~3 degree field, you'll have lower quality PSF to the edge, but that nice big field.    If you want to see what the smaller/higher quality field use case looks like, see my page or other user pages with RASA+ASI183.
https://www.astrobin.com/users/dmsummers/
Best wishes as you sort out what you are trying to do....   CS   DougS
pgazmuri 1.43
Is the RASA your first scope?  That's a LOT of telescope to start with, it's very tricky. Challenges with RASA:
* You need perfect backfocus. A Hair's width misalignment is enough to be out of focus.
* You can't really put a filter wheel on there without blocking a lot of light, so you need a filter drawer system of some kind.
* Flats can be very challenging to get right - I recommend "low and slow" where you use a barely illuminated wall or ceiling such that you can expose for 30-60 seconds per flat. I have no idea why you need to do this, but it's the only way that worked for me.
* You will get heavy vignetting, I don't recommend a full frame sensor for that reason, the ZWO2600MM and ZWO2600MC are very good matches for the RASA IMO. There are some mods you can make to reduce the vignetting.
I do mostly narrowband imaging, so I got the mono cam and use 7 different filters. Swapping the filters manually is a pain, and sometimes I wish I just had a OSC camera, but then my narrowband images would be noisier. Here's the thing, once you mount the camera and get it in focus, you aren't going to touch it for a loong time.  Getting that backfocus distance perfect required .1 and .2mm spacer rings and checking for field curvature using some software program (don't remember which). Plan to waste at least one evening getting your backfocus perfect.
If you get a mono cam, you need to get filters, and you need to get fast filters that support F2.2. These are expensive and will require the filter drawer and time swapping, etc… an RGB cam will be simpler, so for just getting started maybe you do go that route.
Given that you can't take this thing apart and put it together within a single session, you need to get a tripod like wheelie bars so you can keep it setup and just roll it out when you want to use it.
I recommend mounting the PC directly to the scope, getting a heated dew shield, a guidescope (don't forget a dewheater for that too!), temperhum sensor, external wifi module if needed. Dew shield and pc can be mounted with bungee. Mount batteries onto the tripod.
It's a fantastic scope but it's very finicky to get working.  I last re-set mine up 18 months ago and it's been perfect this whole time, so once it's setup it should be reliable.
Where are you getting stuck otherwise? Any specific questions?
tommax1 0.00
I have used many ZWO one shot color (OSC) cameras on my RASA 11 over the years, from ASI2600MC Pro, ASI2400MC Pro, ASI294MC Pro, and my ASI533MC Pro which is currently on it.  I do have decent luck with a filter drawer where you can add one 2" filter in such as a light pollution or nebula filters.  If you put a filter wheel in from of that telescope you will get whacky 3 and not 4 full star spikes which looks funny.  QHY10 was also great on this scope for many months.
There is a good web site called Astronomy Tools (https://astronomy.tools/calculators/ccd_suitability) that will allow you to pick your scope and camera and it will tell you if the combination is over or under-sampled.  This is not super critical, but should really be factored into your decision, especially if you want good results with the least pain.  Also that site will give you the Field of View or what you will see with respect to known astro objects, like M311 for example. https://astronomy.tools/calculators/field_of_view.
Also seeing pictures from other astrophotographers has inspired more than one scope and camera purchase so that also can be helpful.
This is not a quick start hobby.  For a first scope I would not have recommended either the RASA or the Edge SCT, but a small refractor.  They are simple and will give you the best results with the least learning curve.  That said the RASA is an awesome scope but suffers from some ills being so fast at f/2.2.  Try not to let it frustrate you, ask questions, there are tons of people that did what you are doing and are happy to help, but you need to have reasonable expectations.  I have been doing this for almost 10 years and have 2 backyard observatories and still struggle at times.
Clear Skies,
Tom
rallyho 0.00
ZWO ASI2600MC Duo
Pyrasanth 2.41
Whilst I'm mindful of the question you are asking there are a few things to consider , along with the camera, that may make your life easier- one you've mentioned is automated focusing. Remember that some automated focusers have variable backlash like the ZWO that can be difficult to tame as it is often inconsistent and varies according to temperature and thread travel when it moves the RASA mirror. I find the Pegasus Zero much better in this respect as it has no or very little backlash.
I would suggest you explore the Baader UFC filter system for your RASA and initially use the ASI2600 class of camera as it is not so demanding on the requirement to be using a totally flat field. I would only consider the IMX455 sensor when you are comfortable that your field is flat with an initial APS-C size sensor- there really is a world of difference in the need to be very precise when you venture into full frame sensors with the RASA 11.
Having an accurate, as mentioned, automated focusing system with no backlash will make your life much easier as the step size to accurately focus needs to be in micro metres which is easily achieved with electronic devices. Backlash can cause your V-curves to be inaccurate and in worse cases can take much longer to achieve focus than what would normally be expected.
Back focus needs to be precisely at 72.8 mm for the RASA 11 and you do need to take into account the change of focal length from the use of filters.
I also suggest you get yourself a precise parts custom adapter that screws over the camera mounting assembly and dispense with the locking ring clamp that compresses the default camera plate for camera attachment- its felt back can cause tilt. The Assembly with a rotator can be seen in this post https://www.cloudynights.com/topic/908836-a-most-fortunate-configuration-event-very-rare-three-lucky-strikes/
With the RASA V2 the mirror alignment in my experience is quite precise. I've never needed to collimate the lens assembly. I suggest you explore back focus and adapter levelling before even touching the lens collimation to avoid perhaps an unnecessary world of pain.
Automated focusing needs to happen on each filter change and at least every 30 minutes in environments with rapid temperature changes. The focus is sufficiently sensitive to this.
There is a lot initially to consider for a new RASA setup. When you get these aspects fine tuned it is a very rewarding instrument but don't be frustrated if you don't get instant optimal results you just need to be patient and work through each challenge. Celestron never said it was going to be an easy instrument to  set up and get working well. I think they are a bit liberal with some basic facts that would make us better informed before committing to a purchase.
Good luck.
Best wishes,
Mark
EmeraldHillsSkies 0.00
Hello @CMStars .  Sound@MARK Shelton  knows what he's talking about (above). I use a RASA 11 with a ZWO 2600MC Pro and I love it. Last night, using EAA best practices, I observed mag 18 galaxies that my atlas software said were not technically possible with a scope the size of mine. You've chosen a great instrument. But Mark and the others are right. This thing is sooooooooo picky. If I were you, I would indeed start with a 183 and work out the bugs with that. Then, once you feel like you're confident, add a 2600 MC Pro (but don't sell the 183 to buy it; you might decide to go back to the 183 haha). Honestly. That's the way to go for multiple reasons. You'll love this rig. In a word, it's astonishing.
Doug
https://www.EmeraldHillsSkies.com
smccully 0.00
This is all really great advice, I would add one additional tool to look into  http://telescopius.com if you're not already aware of it.
The telescope similar is a great way to plan and compare different camera/scope combinations, as well for planning once you start taking pictures.
Sean
Marcelof 6.20
You don't mention the mount, which is by far the most important element in this hobby, so what mount will you use?
And I'm sorry, you're not going to like this, but learning AP with a RASA, as already mentioned is really challenging, almost guaranteed frustration. Since you mention a second telescope, leave the RASA in its box and get a small refractor, as a camera get the ZWO 2600 color, learn AP with this setup, dedicate about 1 year to it.
Only then take the RASA out of the box.
bsteeve 11.22
no matter what camera you get you better get this to get it working: https://www.asgastronomy.com/photon-cage/
BPS 0.00
I own the Starizona Hyperstar V4 paired with the C/8 Edge HD. My camera is the ASI 294MCP and used it as my primary imaging train for a season. Both the camera and Hyperstar are excellent pieces of equipment with one cavate. The 294mcp requires flats that are > 2 seconds. The Rasa and Hyperstar are light gathering cannons and I found it challenging to say the least to manage flats.  Personally (I am an amateur and not an expert) I would opt for the ASI 183MCP or ASI 533MCP and shy away from the 294. for one shot color.
Then of course as stated above you will have to get filters designed for the fast setup.
Have a great time with your new setup! smile
Bazarov 0.00
I use the ZWO ASI2600MC Pro with my RASA11 and have been getting some decent results with it.  I use either an IDAS NBZ nebula-enhancing filter or an Optolong L-Pro, mounted in a filter drawer.  I have the scope assembly mounted on an AP1200GTO, an old but solid mount which has proven quite reliable.  I use a mini-Borg 50 scope for guiding, with a Starlight Xpress Ultrastar guide camera.  I do focusing with the aid of a ZWO EAF.  For capture software I use Sequence Generator Pro.
I agree with the people who say you should get a small refractor first and learn to do imaging with that before you try a temperamental beast like the RASA11. That said, I haven't found the RASA11 extremely temperamental.  But it does have its idiosyncrasies, and one of them is that focusing can be a challenge, especially at the outset.
I learned to do astrophotography with a William Optics FLT-132 refractor.   I would recommend starting out with a smaller scope like the WO Redcat or one of the other refractors, nothing bigger than 70-80mm at first.
Whichever way you go in the end, I wish you the best of luck.
Cheerio
Jerry L. Floyd
astronomical_horizon 1.20
I can advise a Touptek 2600mc. The body of it is smaller then the ZWO ASI ones, so you have less obstroction
Pyrasanth 2.41
Marc-Antonio Fischer:
There will be no obstruction with either round camera, ZWO or Touptek, on the RASA 11 as the round camera diameters are smaller than the secondary lens assembly so unless your camera diameter is greater than 116mm (I believe) this will not be an issue. You can make a ring that you can fit inside a dew shield to loop the cable thus avoiding diffraction spikes.
MARK Shelton:
You are right. The rasa 11 is larger. So it wont make a difference, besind 1000€ in price
Pyrasanth 2.41
I found that the RASA 11" can be used with the CEM70G mount which I have however I've got an upgrade in place for the CEM120. The RASA 11" is surprisingly bigger than the C11 SCT so a beefier mount is beneficial.
(deleted)
jprovi57 0.00
I have the RASA11 V2 for several years - I would recommend the ZWO ASI2600MC Duo OSC - easier to collect data and process than mono. The Duo built in guider will take into account any potential mirror flop as well - works fine with dual narrowband (Ha and O3) filters.  I would also recommend purchasing the RASA 11 ASG Photon Cage, the RASA 11 Standard M54 package with built in filter adapter (see https://www.asgastronomy.com/store/asg-photon-cage-rasa-11-m54-package/) - the Photon Cage will provide tilt, precise backfocus, and removable filter slider capabilities.  Finally, you will need dew shield - I would recommend Celestron's aluminum dew shield with cover cap as well as Celestron dew heater ring (it will need a regulated heater power as a function of outside temperature - dew heater controller).  enjoy the RASA 11
gnnyman 6.04
I am using my RASA11 with two sensor sizes (most of the time) - either for large overview the QHY600 (both - depending on target) and for details the 183 (both - depending on target). The first gives me the full field of view (alignment is a bit tricky to get all corners OK) and the second one allows me to grab details, benefiting from f/2.2
The RASA11 is an excellent instrument - I do like it very much.
CMStars 0.00
Thank you to everyone for all the knowledge and suggestions!  A bit overwhelming… After reading through all the replies I can see I have a lot of learning ahead of me.  So many of you suggested the ASI2600mc so that is what I ordered.  High Point mentioned the duo had some issues so I went with the pro (even though it’s on b/o.)  I already have the Celestron auto guider so I assume that will work?  Did I make the right choice?
I also ordered the Photon adapter system (with filters) the L-extreme filter, dew ring & controller.
I neglected to inform that I’m using CGX mount.
I  went ahead and ordered the 8” EdgeHD bundle, ASI533mc pro, optolong uhd filter, dew ring,  Apertura all night power supply, Lepus telecompressor and wide angle eyepiece kit.
Have  I missed anything?  (Except for the challenge of learning).
Thanks again!!!  What a wonderful community!
 I can’t wait to post my first pic!
CMStars 0.00
I appreciate your input!  I have the CGX mount.  I am always up for a challenge… so judging by your comments I guess I can expect this one to take me to where no man has gone before
(deleted)
CMStars 0.00
1.  I bought the L-Extreme f2 for the rasa and the optilong UHD for the Edge HD
2.  I bought the Celestron dew ring and Celestron controller 4x
3.  Since I haven’t even got to the point of taking an image yet… I appreciate the info (I’m looking forward to that stage and the learning curve there as well!)   I’m learning this hobby isn’t something you just jump into and get results.
I am second guessing ordering the asi2600mc pro instead of the duo.  (Based off of the input from the salesman at High Point / stating they get several calls about image problems stemming from the 2 cameras competing).  I’m wondering if the guiding from the duo would work better than the Celestron auto guider?  And if any other users have had issues with the duo ?
Bazarov 0.00
No, the guiding from the Duo will NOT work any better than the Celestron auto guider, or any auto guider.  The two ZWO cameras DO compete with one another.  I have not been able to get two ZWO cameras to work together with my setup EVER.  ZWO needs to fix that, and as far as I know, they haven't done so yet.
