I Haven't Yet Mastered Collimation with the Edge HD 8 Celestron EdgeHD 8" · Jerry Gerber · ... · 37 · 2145 · 31
drblevy13 2.62
While not identical, I have an EdgeHD 11 and swear by Metaguide for focused star collimation. That was how I originally discovered that my 2600 camera fan was introducing vibration. Agree with the suggested fan replacement as posted earlier.
There is a phenomenal how-to video on YouTube from Frank Freestar8n, who wrote the program and is a great instructor:
https://www.youtube.com/live/hZV43ZHNUKM?si=xIRdO_0a9ERJOdRG
Leonardo-Ruiz 4.01
I have been enjoying various telescopes for 26 years. My first telescope was a Soligor brand Newton that I still have. I learned to collimate this Newton when laser collimators, computer programs, digital cameras, tribahthinov masks or special Knobs did not exist and it has never taken more than 5 minutes to get it perfect.
A few years ago I acquired a celestron C8 EDGE, a wonderful telescope but with complicated collimation, especially for beginners.
When I started collimating the C8 I noticed a big difference compared to the Newton. The screws were looser, they did not feel firm and most importantly on the C8 when I tightened a screw and loosened it again or did not notice the mirror return to its initial position, which forced me a multitude of extra corrections compared to the Newton .
I disassembled both secondary mirrors, to see the differences. I attach photos.
Newton:
Celestron C8 EDGE. No tension.
The two huge differences are, firstly, that the Newton has a spring that tensions the secondary mirror and secondly, the mirror is held by a tilting screw.This has enormous advantages. The first, when under tension the screws are firmer and greater control is obtained when tightening and loosening. The second and most important, when a screw is loosened, the spring pushes the mirror, so we have total control without the need to adjust other screws. Finally, the presence of the tilting screw prevents accidents, since if it were not there, as happens in the Celestron C8, if we loosen the 3 screws too much the secondary mirror would fall on the primary one.
To obtain the advantages of the secondary mirror that appears in many Newton telescopes, I propose two improvements that are very economical.
The first is to place a spring 7 to 10 mm wide by 5 mm high on the axis with a blunt tip where the mirror tilts. It is an easy spring to acquire and find in a multitude of components that we have at home. With this we will have the tension that will help us in collimation. The second improvement is to change the screws for about 10 mm longer, which provides greater security.
Sometimes when the collimation is achieved, the screws are not firmly secured, so they decollimate when changing position. It is not for nothing that many users collimate with Jupiter's moons before pointing at Jupiter, so as not to move the telescope too much. This problem is eliminated with spring tension.
I have made these improvements and I can calibrate perfectly in less than 10 minutes, without stress, without problems. When I collimated without the central spring I spent 2 hours on it and never obtained the desired collimation. Of course experience helps and celestron owners acquire skill and achieve perfect collimations in minutes, even more so with the new accessories that are available to help.
I hope that helps.
smcx 3.61
Interesting solution!
Paulinho 5.01
Leonardo Ruiz:
Hi, Leonardo.
This is excellent.  I wondered why Celestron did not have any spring or other such mechanism for maintaining tension, but being fairly new to this sport, figured they know more than me.  But 1.5-2 hrs and a lot of hair pulling is no fun (and nobody warns you ).  10mins sounds damn good!  So your central spring improvement is something I am going to try.
How stiff should the spring be?  Any example devices that would have a comparable spring, or tips on what other toys to pull apart to get a suitable one?
Cheers.
Paul
Leonardo-Ruiz 4.01
Hi Paul,
The important thing is that it is a compression spring and that once compressed it is not greater than 4 or 5 mm, since that distance is being removed from the thread pitch that holds the mirror and if you loosen the screws it can fall. That is why I also recommended replacing the screws with about 10 mm longer, to maintain the maximum length of the screw within the fastening.
I show you the screw that I used. I took photos, the length differs from the photo because I cut it and used the smallest part of 8mm and the photo shows the remaining part which is 12mm.
I used the spring from an aluminum door lock.
There are many compression springs available on Amazon. I'll copy you one, that is very similar:
Compressed Spring,Wire Diameter 0.03",OD 0.2",Free Length 0.39" Spring Steel Extended Coil Compression Spring 10Pcs
To install the spring, it is easiest to remove two of the 3 screws and loosen the third. With that, we get the angle, we turn the mirror until it is on top of the spring and we place the rest of the screws. It is very important that you leave the base of the mirror as parallel as possible to the support. With that you will have 90% of the collimation.
Then, with the mirror in your hand, loosen the screws a full turn and check that you still have a good grip on the mirror. If not, the spring is too long and you should cut it by 2 mm. If you have a good grip, squeeze them again and you already know that you can collimate by loosening up to one turn safely, but if you have left it fairly parallel, you will not need to loosen as much.
Clean the mirror.
When you start collimating, use very gentle 1/10th of a turn movements.
Good Luck.
Paulinho 5.01
Thanks, Leonardo.
Super helpful!  And I expect many others will find it so as well.
Cheers.
Paul
Kanadalainen 6.10
Hi Leonardo,
Thanks for your help and suggestions, this is a nice idea.  I may have missed it, but could you please append an image of the new screws used side by side with the original?  I noted the compression spring height.  Thanks again for this solution.
Kind regards,
Ian
_The3D_ 2.86
an important thing to consider is that the mechanical center is not always the right alignment, as the optical center may differ. I used my OCAL (which i used successfully to collimate my RC and my newtonians) on my C11, it looked way out of alignment from the OCAL although the star test actually looked pretty good. I got everything aligned perfectly thinking i would finally get an amazing collimation but the result once i checked using a star was a disaster, scope was completely miscollimated. Had to redo the collimation using the defocused star, i checked the day after using the OCAL, and it looked misaligned again. That's just how my scope needs to be.
Leonardo-Ruiz 4.01
Ian Dixon:
Hi Leonardo,
Kind regards,
Ian
Hi, Ian.
I show you an image showing the secondary mirror measurements of my Celestron C8 EDGE.
The factory screw is 12 mm. 5 mm remain inside the upper support, 4 mm is the original spacing that I have not modified to avoid variations in the Back focus, approximately 3 mm is what remains pinked and is what maintains the secondary mirror.
The total thread of the lower support is approximately 8 mm, so if we want to have more security and support and take advantage of the 8 mm thread, the screw would have to measure 5mm+4mm+8mm= 17 mm long. I have used the 16mm screw which gives you 8mm clamping, which threads the entire clamping body and I can see when it goes through it. When it appears just half a mm from the screw at the bottom of the fastener, I know I'm at 4mm of spacing.
On the other hand, I measured how much the screw rose or fell when turning it one full turn and it is approximately 0.5 mm.
I adjust, with the mirror in hand, each screw until I have a spacing of exactly 4mm.
Once you have the 4 mm spacing on each screw, the mirror is level and when collimating it is already very close to the desired point, with less than one turn on each screw you reach the desired point, which maintains 8mm of support and together with the tension of the screw it maintains collimation.
I have my C8 in an observatory at my house and I don't take it on trips, so I can't tell you if it holds up to collimation when you take it by car.
I am Spanish, living in Mexico and a week ago the rainy season began, that will last until October. When I have a clear sky I will send you collimation data using CCD Inspector, a Tri-Bahtinov mask and some tilt correction tests of the camera chip.
Good luck
Kanadalainen 6.10
Leonardo Ruiz:
Ian Dixon:
Hi Leonardo,
Kind regards,
Ian
Hi, Ian.
I am Spanish, living in Mexico and a week ago the rainy season began, that will last until October. When I have a clear sky I will send you collimation data using CD Inspector, a Tri-Bahtinov mask and some tilt correction tests of the camera chip.
Good luck
Thanks Leonardo, your response is super precise and useful!!
Kind regards,  Ian
cgrobi 7.16
Emilio Frangella:
This thread is indeed very interesting.
I got my EdgeHD 8 about 3 weeks ago and for several reasons had only two nights to set it up. I got mine shipped and after seeing the first stars with really odd shapes, I had to collimate it with the unfocused star method. This worked quite well for my taste. But when taking flats, I noticed that the optical center is not at the center of my sensor. The vignetting is not even on all corners and the brightest spot is abot 5 to 10% off center. I don't think that tilt exlains this much offset. But there is no obvious way to adjust all the optical parts other than the secondary mirror. Even the manual only talks about using this one to collimate.
However, I had the same issue with both of my Newtons and as hard as I tried to fix this, I was not able to solve the problem. The Edge on the other hand shows much less of this behaviour and the subs looked quite good though. In my case, I like the fact that the whole imaging equipment is screwed together and this way is very rigid. This should (at least in my mind) reduce tilt to a minimum. I'm still a little bit off with backfocus, but after adjusting it, I will give it a first try and collect enough data for a first final image. Then I will judge again and see what to do next.
But I also experienced that my 3 refractors worked really good out of the box. Although they have a smaller aperture than my Newtons, I really enjoy imaging with them. I also own a RC8 with which I have a love and hate relationship. The Edge works much better (In case you may ask, I got a really good offer I could not resist).
Thinking about all this, I think that I may have the same problem as Jerry with his red circle alignment. Something other than the secondary mirror seems to be off center.
Christian
aabosarah 9.31
Emilio Frangella:
This is exactly the problem the OP is having. @Jerry Gerber you are not doing anything wrong. The Ocal is simply the wrong tool for this OTA. I have two Ocal collimators. They are useless for collimating my SCT / C11. I would get perfect mechanical alignment but optical alignment is way off.
With those OTAs, your best bet is to use the defocused star method initially to get the CO roughly in the middle, and then using a tribhatinov mask to dial it in some more. This most often is enough to get you good collimation for long exposure astrophotography.
Now if you are into high resolution planetary imaging, this is not good enough. You will need to collimate using something like Metaguide to really dial it in.
Leonardo-Ruiz 4.01
The clouds are finally starting to leave and yesterday it was perfectly clear for a few hours.
I was able to collimate the C8 EDGE like never before. I'll tell you how I did it.
First, after installing the compression spring and changing the screws to M3 16 mm,I made sure the distance between the base and the mirror was exactly 4mm on each screw.
I placed the secondary mirror and defocused. Then I focused to see what it looked like with the Tri-Bahtinov mask.
Now the collimation begins. First of all I used Asi Air Plus so I could have the phone next to the telescope. I chose the focus function as it allows me to take photos every second and I can see the changes in real time. The success of this collimation, unlike other attempts, is that the star occupies 100% of the screen, which forces me to make micro adjustments to avoid losing the field of view. I make a minor adjustment and re-center. Initially it seems inappropriate but the collimation is very sensitive and so you are very safe. To collimate I do as always, I tighten the screw in the narrowest area and when they are very similar, I use a transparent millimeter ruler. I measure each part and always compare and adjust to the narrowest part. When I want to go back I simply loosen the screw and the spring returns it, it is the same as tightening the two opposite screws.
The result after just over 15 minutes:
 I focus and put the Tri-Bahtinov mask on, to see how it looks.
I see that the mask is more precise than the blurring technique, so I do the first steps with the star out of focus and after putting the mask on,  the micro adjustment can be made.
In my case it was almost perfect but I made some micro adjustments looking for the best approximation. The result:
My problem was Back focus. When I used the manual filter holder the entire system was 105.3 mm, but when I put in the EFW it was 1 mm shorter. When I did the collimation everything looked fine, but the stars were very big.
I got a 1mm spacer and it reduced the size considerably. So the first thing to check is that you have the 105.3 mm Back focus and then start with the collimation.
I did a test to see the size of the stars and I loved the result, because with processing in Pix Insight we know that we can reduce the size of the stars and improve them if necessary.
The test, 300 s BIN 1 on NGC 7000, The Wall.
I hope it's helpful. Thank you for asking, because trying to find a better solution, I have perfected my collimation technique in a simple way and understanding how my equipment works.
Now it's time to enjoy.
