what accessoires for mount dslr and stay visual Celestron C8 · Gaiden · ... · 16 · 1005 · 4
Gaiden 0.00
Hi everybody!
please, forgive my English, but I'm Italian..
I'm here to ask you an advice about my setup.
I have a Celestron SCT C8 and I would to use it in both visual and photo.
For now I have the original visual back and the diagonal mirror
I'd like to have an easier and quicker way to change eyepieces (just eyepieces 31.8mm) and, why not, a focuser integrated to the eyepieces support.
About photo, I have a Canon EOS 500D (soon defiltered in full spectrum) and I would mount it with the celestron focal reducer and probably with something to manager filters
well, I searched for something proposed by Baader planetarium like T2 System but I get totally lost with different parts! they're sooo much!!!
Do you have something to advice me?
Thank you!
Ciao,
Immagino che tu abbia l'adattatore per la flangia SCT. Al fuoco secondario del C8 ci devono essere circa 150 mm dalla flangia al fuoco. Detto questo, per collegare una Canon al C8 hai bisogno di un adattatore T2 (M42) per Canon o di uno M48 sempre per Canon se la flangia a cui va avvitato lo richiede, per es. un riduttore focale. In genere l'adattatore T2 (M42) va per la maggiore. Sconsiglio l'uso del riduttore focale della Celestron se non e' uno Edge HD. Molto meglio il seguente: https://starizona.com/products/starizona-sct-corrector-63x-reducer-coma-corrector . Per un focheggiatore esterno consiglio il Baader Steetrack.
Whatizits 0.00
I have never found the changing of eyepieces to be a particularly difficult task, even with the stock equipment.
bdu 0.00
I replaced the visual back with the Baader ClickLock which works well to swap between 2 inch diagonal for eyepieces and a DSLR with a nosepiece. This works with or without the reducer.
Gaiden 0.00
Ciao,
grazie. ho già il correttore celestron e ancora non ho nessuna flangia
Bart:
*thank you! do you have a link to share?
bdu 0.00
https://www.baader-planetarium.com/en/baader-2%22-clicklock-eyepiece-clamps.html #2956220
Herbert_Hamber 0.00
Salve,
The Celestron f/6.3 reducer flattener you have works very well, in spite of unfounded claims to the contrary.
For photography just get the Celestron adapter with Canon T2 mount, no need to get anything else :
https://www.amazon.com/Celestron-T-Adapter-9-25-Black-93633/dp/B07TMD2CW8
For visual the original Celestron visual back (SCT to 1.25") and diagonal + 1.25" eypieces work very well.
An upgrade (at a price) might be a Celestron 2" XLT  diagonal + 2" eyepieces.
Generally you can easily spend a ton of money on shiny gadgets and still achieve zero improvement, so carefully weigh your options ...
A filter wheel is not too expensive but you have to decide on filter size (1.25" vs 2") :
https://www.amazon.com/SVBONY-Multiple-Position-Telescope-Eyepiece/dp/B07W5L76FX?th=1
You can see pictures of my (five year old) Celestron 8 inch setup here :
https://www.cloudynights.com/topic/826723-nexstar-8se-imaging/
Buona fortuna, HWH
Gaiden 0.00
Herbert W Hamber:
Salve,
Buona fortuna, HWH
*thank you for answering! I'm waiting for the adapter in the pic (93633)
I can't decide for the filters: for example, in the configuration showed in the last pic where I will place filter? I don't think that the adapter could receive a filter...
Herbert_Hamber 0.00
Salve,
I used a SVbony clip-in filter for the Canon EOS EF-mount ... fits perfectly ... H alpha and UCH ... they are not cheap so be careful with your choices.
https://www.amazon.com/SVBONY-H-Alpha-Narrowband-Astronomical-Photographic/dp/B07HQDVQFS
https://www.amazon.com/SVBONY-Astrophotography-Contrast-Pollution-inch-EOS-C/dp/B07DDJLNPT?th=1
Buona fortuna ! HWH
Herbert_Hamber 0.00
You can always mount your camera with a 1.25" visual back, adapter and T2 mount.
It works quite well (I have used it many times over the years) and you do get just a tiny bit more vignetting.
Herbert_Hamber 0.00
Even a 2" diagonal works :
Herbert_Hamber 0.00
Let me know what you chose ... I also have an svbony filter wheel but have not used it yet :
https://www.ebay.com/itm/313789084244
The clip-in filters are very convenient to use for the Canon, but then you have to take the camera/lens out.
Gaiden 0.00
I think I go to convert my EOS 500D in a defiltered full spectrum.
Herbert_Hamber 0.00
Allora come e' andata ?
Gaiden 0.00
I'm thinking to buy this two guys here : https://artesky.it/artesky/focheggiatori/75-focheggiatore-elicoidale-da-508mm-artesky-8055517130346.htmlhttps://artesky.it/artesky/diagonali/4506-diagonale-2-fast-lock-dielettrico-90-artesky-8055517133378.html
I'm not sure it's a good choice and I am a little in doubt about mounting the focuser on sct filetage
Herbert_Hamber 0.00
Don't know about the first item, but I do have the Celestron 2" dielectric diagonal (similar to the one above) and it's nice !
L'astronomia puo' diventare un pozzo di soldi senza fondo :-)  …    [email][email protected][/email]
SouthWestAstro 0.90
I second comments about the Celestron f/6.3 reducer/fllattener. It works very well and is excellent value. Don't let anyone tell you differently.
Any of the 2 inch visual backs that you can get on Amazon would be great:
https://www.amazon.com/Astronomy-Telescope-Adapter-Schmidt-Cassegrain/dp/B07V6W9VTM/ref=sr_1_3?crid=2P3A4LHYK9GXZ&keywords=1+inch+visual+back&qid=1676752692&s=electronics&sprefix=1+inch+visual+back%2Celectronics%2C118&sr=1-3
I like to say that Celestron's standard visual back for their SCT's is the "work of the Devil". Compression rings only for me. But I see that other knowledgable people see it differently.
The Baader click locks are also good.
I would also recommend a 2 inch diagonal
The views from a C8 with a 2 inch 40 mm eyepiece are really enjoyable.
