Oscar:
same happened with me
Did yours end up at the same place? On the photo, the connector was not tightened yet, just at the end of the thread. Think it will move a few more mm when tightened. This makes me wonder how much spacers I need to add to position the OAG prism away from the sensor, messing up the 55mm back focus completely...
It really looked like a brilliant setup that the Askar OAG has and being flexible with lining out on the camera sensor, but this is just useless... Very disappointed with this. I am still hoping I am doing something completely wrong!
well, yes I think so, but I tried tightening it as much as possible, and obviously, it still wasn't enough, since I had to resort to cutting out an aluminum spacer
it's easy, just use one sheet of foil, then two, then three, etc, until you have the correct position
I just think the Askar OAG was made to be used with the Askar filter drawer more than with any other configuration, but that doesn't mean it can't be used with an EFW - I did it, and I had a tilt plate, and I got good stars
I still recommend, people who buy an EFW should get the ZWO OAG, not the Askar - the ZWO also has the added benefit of being able to be bolted to the EFW
I like the bolting, because, well, the Askar OAG can be wiggled; I was once getting tilt in my system and found out my OAG was tilted by 1-2mm, all because of that 3 lip attachment design which doesn't guarantee totally flat contact between the OAG and EFW; I had to push the OAG against the EFW and use pliers to really tighten the 3 lip screws, to finally get a perfect flat contact (I think maybe this whole tilt problem was because of the foil I added, but, it serves it's purpose pretty good
, I guess it would be better if you use some solid metal, thin spacers)
another thing, be careful with the prism, don't touch the screw that tightens the prism into place and also don't force the stalk into the OAG; I tightened the screw (because I thought the prism was too wiggly; it actually fell out at least once, thankfully, not when the OAG was attached to the image train), and I forced the stalk into the OAG and cracked the whole dang prism, but I still sometimes get guiding numbers down to 0.27" total RMS, so I'm still pretty happy with it
