I used two rectangular spacers provided with the kit for the proper tension of a timing belt. During focusing using the EAF I found that it slightly lifts its holder. I recorded this effect by squishing the timing belt with my fingers:
https://youtu.be/u1fMK-j4sD8
I also found that the kit has an unused hole with M3 nut inside, so I designed and printed a kind of supporting bracket::
Now the problem is solved:
https://youtu.be/GAKcSS1952o
I'm happy to share an STL file if someone wants to improve their EAF kit.
