ZWO CAA for the 6" Carbonstar Apertura 6" f/9 Ritchey-Chretien · Keith Geissler · ... · 6 · 284 · 0
kgeissler 1.91
I have the 6" Carbonstar RC and am thinking about buying the ZWO CAA rotator.
My current configuration is Scope -> Tilt plate -> Focuser -> Manual Rotator ->Askar OAG -> Askar Filter Drawer - > Camera
Can I take out the Manual Rotator and install the CAA in the image train (not necessarily in the same place as the manual rotator)?  I am not sure how backfocus works on the RC6.  I think it would work, but just wanted others opinions before I buy.
Thanks
jbozeman 0.00
The ZWO CAA rotator hasn't been released yet. It doesn't look like it will be any time soon.
kgeissler 1.91
John Bozeman:
It was released at the end of December.  It's currently backordered.
https://www.highpointscientific.com/zwo-caa-camera-angle-adjuster
As someone who really cares about composition I'm out there rotating the camera all the time. It would be wonderful to just sit at my desk and do it. It's on my short list of upgrades for sure.
Curiosity_Astro 0.00
Since you aren't using a focal reducer, you can realistically install the CAA wherever you want. There's no strict back focus requirement on these Ritchey's, and if you can reach focus because you don't have enough in-travel, just take one of the extension tubes out. Super easy to work out.
Elmiko 10.75
Hi Kieth.
I have two of the Zwo Caa Rotators. I ordered mine on December 26th, the day it was released.
I have mine on two Refractors. The Telescope side of the rotator has an M54 female thread. So if you don't have a male M54 adapter you will need to order one. The camera side of the rotator comes with two adapters an M 54 and an M 48 female.
I have mine installed on the ends of the focuser tube, then a filter drawer, then the camera.
I know that they're back ordered, but worth the wait. It's a great piece of equipment.
Hope this helps.
Mike
kgeissler 1.91
Shawn Thiessen:
the only problem I saw that my OAG would be very close to where the CAA is.  No room really for the CAA to rotate, without hitting the focuser of the OAG.  Right now my RC has the one 50mm long tube coming out of the OTA.  I thought i could use the 25mm tube instead.  Then add a 25mm spacer after the rotator.   Basically just move that 25mm from the tube to a different spot in the image train. That way the CAA won't rube the OAG.
