telescope lunar imaging in daylight [Solar System] Acquisition techniques · [email protected] · ... · 2 · 125 · 0
whistongs@btinternet.com 0.00
In UK summer most observing time is in twilight - AM&PM and seeing is sometimes reasonable - I need help on aquisition, filters and technique
es
astropical
Hello,
An IR-pass filter blocks visible light allowing lunar imaging during twilight. I am using the Astronomik Pro-Planet 742nm and ZWO IR850nm with good results. Please note that an IR-pass filter requires longer exposure times up to 4x but in turn it compensates for poor seeing to some extend.
Cheers
Robert
wouterdhoye 0.00
I second what Robert says. An IR-pass filter can even allow you to do some imaging during full daylight. You will suffer some loss in contrast, and you do need a really clear sky for best results. I would advise to use a 807 or 850nm filter; the further from visual light the better.
Wouter.
