Rings in image? [Solar System] Acquisition techniques · Konstantin · ... · 30 · 794 · 10
Konstantin 0.00
Ed Astle:
You do have the reducer around the right way?
A reducer around the wrong way "seems to work" but gives a bright outer ring, the antithesis of vignetting.
I know this because I recently got my Daystar 0.5x around the wrong way for solar work.
I looked at every conceivable point of failure before there was only one left - me!
I had T2 both sides and I wasn't paying attention...
It isnt, the reducer 0.6x for 103APO is impossible to put the other way round
Swissiy 0.00
It looks 100 percent like dew. So i bet you did not use a dew heater?
Konstantin 0.00
I did but at the front, maybe dew is forming within the other elements of the scope?
Konstantin:
Not very likely or, more precisely, very very very unlikely for a refractor. You have a inner reflection/light leak issue and that's it.
Konstantin 0.00
I used a 1x flattener that is made for the 103APO and the rings have disappeared!!
There you go, you found the culprit e.g. the reducer/flattener has a reflective component that created the "RING".
