Askar Filter HO + SO [Solar System] Acquisition techniques · Maxime Martin · ... · 2 · 99 · 0
Makesimu 1.81
Hi all,
Today I received my Askar duo Magic Color 6nm HO + SO. I'm really excited to try them.
I actually using L-eXtrem duoband filter and I extract Hydrogen and Oxygen and assembly them for H-HOO combination.
With the Duo Magic Color from Askar filters, I have the possibility to make SHO assembly.
But, I'm questionning about the time exposure from OIII which will be 2 times higher than H and S:
- This 2 times higher exposure time will impact the data processing in PixInsight ?
- There is any "tips" with a higher signal on OIII or it is unnoticeable during data processing ?
Thanks for for advice,
Makesimu 1.81
Sorry for the mistake about the location of the post.
I don't know how to delete it …
WS65 0.90
Hi Martin,
if you use APP you can seperate the channels during processing so you get one H and one O or one S and one O.
If you have objects with a lot of O you can use it in addition, otherwise you can use O only one time.
Another possibility is to reduce blue and green in postprocessing like in PS by ~ 30-50%.
=HwtZe=jCAhz ChMk0b C1N51c=ryNqvbMany roads lead to Rome smile
Werner
