Derotation of Mars [Solar System] Processing techniques · Alien_Enthusiast · ... · 6 · 247 · 0
Alien_Enthusiast 2.86
Dear AstroBinners,
I have R G B frames of Mars,
There is about a 10min delay between them
So when I combine the RGB colors, they don't properly overlap
I need to somehow derotate individual frames
I tried watching a video on Winjupos but it's super complicated
Could someone explain in simple terms what do I click to get individual channels aligned?
Or maybe there is a simple video on it?
TheRoadRanger 1.20
Are they individual frames?? Like did you shoot Mars a similar way you would to a DSO??
If its frames that you've captured from a video the View Into Space has a good video on that
I shot it like DSO
 have red frame
green frame
and blue frame
each 10 min apart
I want to unite them into RGB without colors mixing up - so basically derotate and compose RGB Image
TheRoadRanger 1.20
Alien_Enthusiast:
I shot it like DSO
 have red frame
green frame
and blue frame
each 10 min apart
Not sure I get what you mean by derotate so the colours don’t mix up??
Sam Badcock:
Alien_Enthusiast:
I shot it like DSO
 have red frame
green frame
and blue frame
each 10 min apart
Lets say there is a mountain on mars
Its in the center
But due to 10min rotation of Mars on each of R G B frames
It smears across
And gets a rainbow color on each side due to the fact that each color is a little behind
TheRoadRanger 1.20
Alien_Enthusiast:
Sam Badcock:
Alien_Enthusiast:
I shot it like DSO
 have red frame
green frame
and blue frame
each 10 min apart
Its in the center
It smears across
Ahhhh sweet I’m with you now!! Okay give this video a watch from Sacha Wyss on YouTube!!
Yeah he is processing the moon but the same techniques should be able to be employed and the programs should rotate and frame the individual images correctly for you to the further process
https://youtu.be/8Iyr5W38ZN8?si=mVmDrJIYz3tbn6XX
TheRoadRanger 1.20
You could also use photoshop by loading them into a stack then aligning all 3 frames manually
File -> Scripts or Automate -> load into stack
Choose respective frames
Change the layer type to overlay or screen at say 50% opacity so you can see what your doing
Use the crop tool to manually align the frames over each other
