optical train is (foa-60-->UV/IR cut-->Quark Chromosphere-->asi432mm)
Dark banding or just banding is definitely something that can be addressed by bias/dark removal but you mast have had a rather high gain to be that evident in the stacked frame which is rather unusual as typically the subject's movements within the frame lead to the banding to cancel out.
was using sharpcap, settings below. admittedly, was experimenting with different methods. Is there anything radically different about capturing darks for SER outputs? I assume this is better done via sharpcap? [ZWO ASI432MM] CameraSerialNumber=203252092A010900, via USB3 FrameType=Light Pan=0 Tilt=0 Output Format=SER file (*.ser)(Auto) Binning=1 Capture Area=1608x1104 Colour Space=MONO16 Exposure/Gain Shift=0 Temperature=40.4 Turbo USB=100 Flip=None Frame Rate Limit=Maximum Gain=192 Exposure=1.5010ms Timestamp Frames=Off Brightness=1 Auto Exp Max Gain=175 Auto Exp Max Exp MS=30000 Auto Exp Target Brightness=100 CA Reduction/Synthetic Blue=Off Mask over exposed pixels=Off Flip (after dark/flat)=None Trail Width=3 Minimum Trail Length=100 Trail Detection Sensitivity=9 Remove Satellite Trails=Off Background Subtraction=Off Planet/Disk Stabilization=Off Banding Threshold=20.02111189303308 Banding Suppression=19 Apply Flat=None Hot Pixel Sensitivity=5 Subtract Dark=None DisplayStretchEnable=1 NegativeDisplay=0 Display Black Point=0 Display MidTone Point=0.5 Display White Point=1 Notes= ZWO Focuser (2)=40405 Focuser Temperature=30.100000381469727 iOptron CEM120,70,40,26, GEM, HEM, HAE, HAZ series and SkyHunter Mount=RA=02:32:29.9,Dec=+13:14:05 (JNOW) TimeStamp=2024-04-28T17:20:27.8515702Z SharpCapVersion=4.1.11824.0 StartCapture=2024-04-28T17:20:27.7927726Z MidCapture=2024-04-28T17:21:17.9505275Z EndCapture=2024-04-28T17:22:08.1082825Z JDStartCapture=2460429.222544 JDMidCapture=2460429.223124 JDEndCapture=2460429.223705 Duration=100.316s FrameCount=2000 ActualFrameRate=19.9371fps TimeZone=-7.00 |
Just the same way you would for any other subject as long the same exposure and gain settings are kept and possibly same temperature (not really relevant for bias/very short integrations). Just add the integrated master bias/dark as fits in AS,
I did some review and am now suspicious of the banding supression in Sharpcap as the culprit. It's the only major difference between this SER and prior ones. I left this on for this SER (not purposely, which explains the lower frame rate now) any thoughts? can this banding supression go awry like this? |
Look at the bias. If you see banding then maybe there results are expected but ONLY if somehow solar tracking was really spot on, which I doubt is likely to be. In many many years of planetary imaging I never seen such egregious banding but OTOH I never used banding suppression (and I never would) and my main capture program is FireCapture at any rate.
andrea tasselli: I did finally try out their feature tracking. But I can't imagine it was that good. (seemed awfully chaotic at the time) i've never had banding suppression on before. Will be trying again in about 30 minutes and test it out. |
