The Astrobin All Sky Survey: A proposal for a community resource Other · Brian Boyle · ... · 363 · 13514 · 59
This topic contains a poll.
MichaelRing 4.64
What is the name of the group? I cannot see anything right now, does it need moderation to become visible?
Michael
profbriannz 17.56
Astrobin Community Survey.  I can see the threads on the front page.  But, of course, that doesn't mean I haven't done something wrong.
CS Brian
siovene
You see the threads on the front page because your a member of the group🙂 You know you could just copy paste the URL!
MichaelRing 4.64
Yes, please post the url, I still cannot find the group in explore->groups
siovene
I can’t find it either: perhaps you created a private group instead of a public one.
profbriannz 17.56
https://www.astrobin.com/groups/5818/astrobin-community-survey/
MichaelRing 4.64
I only see an empty, white page. Can you check if the group is nor marked private or similar?
siovene
Definitely private (can’t check right now). @Brian Boyle you can change that using the Edit menu on the groups page.
james.tickner 1.20
Finally some clear weather after almost a month of storms. Managed to grab 2 fields last night and hopefully two more tonight.
ODRedwine 1.51
@Brian Boyle
    I love the idea, but IMHO the real data gap is between 1200mm and  2000mm.
David
OklahomAstro 5.08
As soon as I get my CDK 12.5", I'll gladly contribute, I'm intending on doing various deep fields specifically of Abell Clusters in IR and Visible.
profbriannz 17.56
@David Redwine@V.M Legary   Thank you for your interest.  ThE ABC survey was designed around 100-200mn focal lengths., so we could cover the entire sky in a reasonable time,   After a year was have over 2/3rds of the southern sky completed, although only 10% of the northern sky.  This reflects, in part the difficulty of accessing dark skies in the northern hemisphere.   A survey at other focal lengths would  no doubt be useful, but I will leave others to organize!
CS Brian
OklahomAstro 5.08
Brian Boyle:
CS Brian
Absolutely, I'd go as far to say you could integrate an "enhanced view" using overlays of higher focal length images of notable objects as a modified version of the survey over the main HIPS, like how the standard Stellarium view without HIPS or DSS handles DSO's.
TheRoadRanger 1.20
I would be really interested in participating in this!! I have access to a canon dslr with a "slow" telephoto lens and asi2600mm on a skywatcher scope!! If this works with your parameters you require let me know!! Very new to all this but keen as to get involved and contribute to either one or 2 areas or multiple areas if needed
