There is some peculiar "double wall elliptical asterism" that looks like a very strangely shaped open cluster is first spotted around the SP77 40-9 star using @chilescope T3 (D=0.5m) system:
[1] https://www.astrobin.com/h5fb0p/
[2] https://www.astrobin.com/h5fb0p/L/
and then confirmed using @chilescope T1 (D=1m) system here later (there are more analysis details in the description of [3]):
[3] https://www.astrobin.com/8a27if/
[4] https://www.astrobin.com/8a27if/P/
Surprisingly, instead of dissipating under observation with larger aperture as one would expect from an accident of geometrical arrangement of random objects it appeared more well defined. This makes me wonder what it would looks like if even larger system could target it. Gaia wasn't of much help of making sense out this object, so at this stage I'm not at all sure if the point-like sources forming this elliptical structure are stars and not distant galaxies or components of an unusually complex gravitational lensing image (lifting the restrictions on fantastical scenarios a little
Dear @Gary Imm , @Marcel Drechsler , @Xavier Strottner , @Wolfgang Promper , have you ever seen anything similar in your images or in the literature? @Wolfgang Promper , I was also wondering if you still have access to that ASA AZ1500 system in Chile that might be able to get a better look on this target (at least the pixel scale was smaller for it than that of that of Chilescope T1 system in deep sky configuration)?
This, of course, could be just a stellar remnant of a small HII region embedded into a molecular cloud sitting at the distance to the LMC ("a boring scenario"), but perhaps it is something far more interesting!
Thanks for looking in advance!
Alexandr Zaytsev.
