Science question. Why do stars in open clusters so often appear to line up and appear like beads on a string? Other · Tim Hawkes · ... · 5 · 583 · 1
TimH
One curious question that I have. To my perception anyway, stars in star clusters often appear like beads on a string - often curved strings with dark circles and lanes between. It is quite reminiscent of - albeit on a relatively tiny scale -the way galaxies within superclusters also seem to look like beads on curving strings (in that case presumptively along threads of dark matter).
Does anyone know why stars might  appear to lie along threads in star clusters?  Surmising that the radiation burst from a new star igniting might tend to  trigger more rapid maturation and ignition  of  those proto-stars closest by within the same star-forming molecular cloud.  So the end effect might be  that  lines of stars  form that are aligned along what was originally a ridge of higher molecular cloud density ?   But this is just a wild guess  -- does anyone know what the scientifically accepted answer is ...or am I just imagining the feature in the first place?   See for example in this image of Caroline 's (Herschell) rose (taken a couple of nights ago  PDS200, AS1294MC  51 x 33s).
Tim
aaa_carolsrose_Stack_16bits_55frames_1815s_ABE_COL_MLT_SCNR_TRAN_curves_16bit_PX_mini.jpg
siovene
We are very good at recognizing patterns even in random data. I suppose what you see is just a coincidence, as the same starcluster would look completely different from a different angle, and different stars would make up different patterns.
It is totally random, a.f.a.i.k. The only way NOT to appear to do so would be if the distribution would perfectly spherical. Now, that would require a physical interpetration. Or, seen from another side, just take another piece of the sky with large enough star density (with similar magnitudes) but physically unrelated to each other as they are in an OC. You would see streamers of stars as well, in part becuase that is the way our brain works, making order out of randomly ordered objects.
TimH
Thanks folks.  Yes I do think that you are probably right.
However in researching this a bit more it was interesting to discover that the mainstream view is that star distribution within open star clusters is not random  -- and that indeed by studying star distribution - useful information about the early steps in cluster evolution can be derived."It is known that most stars are born within giant molecular clouds forming clusters (Lada & Lada 2003). Numerical simulations demonstrate that star formation occurs mainly along the patterns defined by the densest regions of the molecular clouds (Bonnell et al. 2003). Thus, the hierarchical structure observed in some open clusters (see, e.g., Larson 1995) is presumably a consequence of its formation in a medium with an underlying fractal structure. "So features of individual open star clusters  can still reflect their origin in density features within their cognate originating cloud.  But in complex and hierarchical ways -- the Bonnell et al work suggests that bigger clusters (e.g 400 stars) might generally accrete from many local subclusters of 10-15 stars that initially formed along local lines  and features  of higher density.So - to me at least (having no PhD in Astrophysics 😊) -   it seems not at all unreasonable to suggest that some of the short curving lines of stars apparent within open star clusters might reflect the remnants of some of these open cluster building blocks  - possibly analogous in some way to the mathematical remnant ‘fractal’ features detected in the second of the two papers below ?https://academic.oup.com/mnras/article/343/2/413/1039210?login=false
https://iopscience.iop.org/article/10.1088/0004-637X/696/2/2086
But I do completely agree that perception completely clouds the issue --- some of the apparent features might be real and, equally, many will just be phantoms.  The problem then being of course that it is completely impossible to distinguish one from the other - or indeed even to know where one might start and the other finish.   Hence the real scientists have used objective techniques for spotting structure -  essentially claiming to distinguish a  surviving 'fractal' type structure more often in younger star clusters and  more centralised radial pattern in older clusters
Tim
ODRedwine 1.51
Pareidolia.
TimH
David Redwine:
Pareidolia.
Thanks.  An excellent new word as well that I have now learned.  Yes it makes sense that that is what it is due to.
