I could put together the following, I already own all the components. I wouldn’t have to buy anything new.
Kasa smart plug to be able to cycle the power.
Pegasus 12v 5a power supply
Pegasus power box micro
Asiair plus
Star adventurer GTI
Samyang/Rokinon 135mm
ZWO EAF
ZWO Mini guide scope
ZWO Guide camera
ZWO ASI533MC
ZWO EFW Mini 5 positions (I don’t think filters are necessary in a bortle 1 site but I have a dark filter in it which I can use for flat darks.)
I wonder if this could work without having to request support every 5 minutes. There’s 2 things I mostly wonder about.
First, how to take flats and flat darks without a flat panel ? One solution I thought of is to use plan mode in the ASIAIR to have a “flats plan” with automatic exposure time starting at a predetermined time using the blue sky as light source. In the morning I could check the length of the exposures and manually run flat darks using that same exposure time.
The 2nd thing I am a bit worried about is power failures or having to power cycle the whole thing. Since the GTI does not have a physical home, how could I “home” it without running into the pier or going full 360 degrees on any axis and wrap my cables around things.
I know most people would not go remote with a GTI and a camera lens, they’d use a small refractor and a ZWO AM3 but I don’t own those and I don’t have $3500 to $4000 to buy it. I am just trying to find a way to use all this expensive equipment I already own more than 2 or 3 clear nights a month.
I emailed this question to Starfront but until they reply I am curious to see what others think. Am I missing something obvious (or not) why it couldn’t work ?
