Organization and cataloging software Other · joshua deherrera · ... · 9 · 211 · 2
MrYoshi 0.00
I like many am getting to point where its getting very hard to keep track of all my data and what the status of every target is.
Is there any software that you can feed in your images and have it build database and keep track of the target address, fov and how many subs of each filter you have etc?
Be even better if it would overlay that onto an interactive all sky globe image for ref.
I envision like how adobe lightroom has the map tab for photo location but with astro coordinates.
ThisIsntRealWakeUp 8.35
@Alex Helms and @Charles Hagen are working on an astrophotography library/target management software called Lumidex. It does not have all the features you've mentioned in your post, but it's the closest I'm aware of. https://github.com/alexhelms/lumidex
This sounds pretty much the feature I'm asking for, well mapping is, see: https://www.astrobin.com/forum/post/191869/
tim.anderson 0.00
Ummm . . . Wouldn't that tool be called Astrobin?
Tim
siovene
Hi think that Joshua would like some features that are currently not available on AstroBin, from what I interpreted. The good news is that I'm just in the planning phase for a set of features that I believe will make Joshua and a lot of people here very happy smile I can't spill the beans with too many details, unfortunately, but I'm very excited, and AstroBin will become even more useful!
dunk 1.81
If you are on a Mac: https://codeobsession.com/observatory/
Wjdrijfhout 6.78
Astroplanner can do some of the things you mention. I use it all the time for planning and cataloging. It is designed with visual astronomy in mind, but almost everything can be adjusted and customized using user-defined fields. I've created a whole bunch of them dedicated to imaging, and find it quite easy to catalogue the status of my sessions. For example I use it to automatically populate the tables on my website for each target. For graphing/tabulating data, you would probably want to use an export to an external program. This can be as simple as Excel, or more advanced visualisation software. The built-in graphing options can give you some of the heat maps that you're looking for, see attached images.
Number of observations per constellation:
Objects photographed:
fenriques 1.81
you can try the software I made for that purpose:
https://github.com/fenriques/AstroDom
Still in beta though.
The idea of an overlay of the sky map is a nice feature, I will add it to the to do list.
Ferrante
MrYoshi 0.00
Will check all out, thank you very much.  This isnt only for my personal imaging. which I could use an online catalog for.
I image for my work as well. My work imaging they require everything be on our internal systems, tightly locked down with zero internet access.
The overlay ask is so TPTB can see updates visually on coverage.
MrYoshi 0.00
My minmum coverage for a work shot is a 20 tile mosaic. Which means I have lot different captures in progress, depending on whats best that day.
