Insurance and Astrophotography Equipment Other · drblevy13 · ... · 17 · 545 · 0
drblevy13 2.62
Hi Folks,
Over the past several years, I have been fortunate enough to build up a solid armament of astrophotography equipment that is stored in my roll-off roof observatory.
How have folks gone about insuring their equipment? Is this through your homeowners policy, or did you take out a separate policy just for your astro stuff?
Clear skies,
Ben
skybob727 6.67
Depends on your insurance carrier, ask them first.
CCDnOES 8.34
In my case they said it was covered under homeowners for the stuff in my roll-off and my  remote site host has insurance to cover that stuff.
One dopey agent suggested I needed a commercial policy until I told her that the total images I have sold amounted to less than .01 % of the cost of the equipment! smile
umasscrew39 13.55
My ROR observatory, that was built on top of my garage,  is covered under my homeowners policy.
bluemoon737 3.61
Covered as an outbuilding on my homeowners policy. I made sure to verify the outbuilding % was sufficient to cover what I have out there.
DalePenkala 19.38
Like @Jeffery Richards my home owners policy is covering my building, however in my case its a percentage of your house so you would want to make sure that percentage is enough to cover the value in the observatory. BTW I have AutoOwners Insurance for both home and auto.
Dale
bluemoon737 3.61
@Dale Penkala mine is the same which is why I mentioned the %...pretty sure that is common for outbuilding coverage on most homeowners policies.
DalePenkala 19.38
Jeffery Richards:
Agreed
Harpo 0.90
Hi Folks,
Clear skies,
Ben
My carrier told me it is covered as part of homeowners protection, but I could add a rider for astro and photography stuff that would also cover accidental drops, scratches, etc. It was pretty cheap to add and covers traveling as well.
Krizan 5.94
Home owners policy.  Photograph and document everything.  Year bought and price.  It also covers while traveling and in the travel trailer. I assume while on the observing field, but not sure. I need to check.  I'm  looking into tamper proof bolts and nuts.  Trumb screws and knobs are designed for easy disassembly,  thats not a goog theft  deterrent.
Lynn K.
jhayes_tucson 26.84
I added a rider to my hangar policy when I had my big scopes out there prior to shipping them to Chile.  It wasn't very expensive.  As most folks have indicated, most home owner polices will cover it; however if your equipment is pretty expensive (like maybe over ~$50k), I'd recommend talking with your agent about it.  They may want a list of what you've got and to call it out on your policy.  I agree totally with Lynn that you should photograph everything and make a list.
drblevy13 2.62
Appreciate everyone's input. Will definitely photograph and itemize everything. Will ask about adding to homeowners insurance and maybe a rider for the equipment itself (especially if it covers accidental damage).
scott1 5.29
I might add to some not to overstate value which may draw attention to yourself. Here in California, homeowners insurance is next to imposable to get from anyone but the state which offers very limited coverage for very high rates. (In my case it costs just over $9000 per year for fire coverage.) No theft coverage.
While I'm not to concerned about theft, fire is a concern.
If I ever have to evacuate again, had to in 03, the first thing going in the car after the pets is all my astro gear.
Scott
psparkman 1.43
My homeowners policy has a $5k per item limit, and my agent said that I would need an appraisal to put my scopes and mounts on a rider.  Does anyone know where I could get appraisals for my astro equipment?
Patrick
drblevy13 2.62
I sure hope my policy doesn't have a $5000 cap per item. The mounts are much more than that!
DalePenkala 19.38
Yes agreed!
psparkman 1.43
Exactly!  My two AP mounts and 3 telescopes are all much more than $5k, so I would really like to get a legit appraisal and put them on a rider.  Bad enough that I would have to wait 1-2 years to replace them if something happened.
DavesView 2.39
I handle insurance through an agent and I run every issue by his people.
