Ambient Humidity vs Indoor Humidity Other · Jerry Gerber · ... · 2 · 88 · 0
jsg 9.55
Hi all,
If the ambient humidity is about 85% outdoors, any one know what the humidity would be at a remote observatory when the roof is closed?
Thanks,
Jerry
Moorefam 3.58
No, not as the question is posed. However if you could say what the temp was at 85% relative humidity (RH) and then ask the question what the relative humidity was with the same airmass at a different temp then this chart will tell you.
https://manual.museum.wa.gov.au/book/export/html/89/index.html
As the chart above shows it depends on the temp. Might be time to add some remote condition sensing to the rig.
