What's the best source out there for spacers, adapters for various thread configurations, shims and such.
Stellarvue has a decent selection: https://www.stellarvue.com/imaging-accessories/ |
3
I second Stellarvue as well as Astro Physics for my refractors and Edge HD11. For basic image train spacers and shims Agena Astro has a good selection. Your specific vendor for your camera, filter wheel, or rotator will likely have a good selection tailored to your specific equipment. Last but not least is Precise Parts (https://www.preciseparts.com/) when you just cant find what you need anywhere else. They will custom build anything you need. CS, Jeff |
Thanks I'll look those over. I want to put together a kit of basic parts so when I have an idea I can just rummage in the bin and put together what I need instead of waiting a week for a part delivery.
Tony Gondola: If only they sold these at the local hardware store, eh? I think most of us can relate. |
lol, in a perfect world….
AliExpress has spacers and adapters of all sizes and colors. And the quality is okay, too.
Tony Gondola: Here is one good source: scopestuff.com. |
Precise Parts
John Hayes: Yeah- forgot about them. I used them many times for specialty sizes when needed. They are excellent. |
I discovered that it's surprisingly easy to 3D-print spacers and adapters, even with very fine threads. While not a good long-term solution, this is good for a quick fix or to check spacing before committing to purchasing the correct part. I second StellarVue as a great source for quality spacers and adapters. Neil |
Special adapters I get from where I bought my telescope. From Amazon I got cheap sets of extensions for T2 and M48. And if I need a mm more or less I just print a shim or use the mechanical workshop at work to shorten a spacer.
for standard pieces, like a set of say M54 extension tubes, aliexpress is by far the most economic solution often running at ~15 euro a piece when a similar tube often costs 40+ euro at other sources. Their search engine is pretty "peculiar" at best, so finding what you are looking for is often a bit cumbersome.
for standard pieces, like a set of say M54 extension tubes, aliexpress is by far the most economic solution often running at ~15 euro a piece when a similar tube often costs 40+ euro at other sources. Their search engine is pretty "peculiar" at best, so finding what you are looking for is often a bit cumbersome. Yes, I've seen a lot of interesting bits there. How long do deliveries take in general? |
When [i] [/i]I need a spacer/adapter, I first look to the scope manufactuer, such as Astro Physics or Takahashi. The problen is there spacers/adapters, as nice as they are, are lilimted and expensive. My goto place is Agena Astro. They carry a number of brands, and Blue Fireball is great for a small spacer or adapter. A note about Blue Fireball: the aluminum is softer and threads can bind. Baader makes good adapters. If you want a high quality one size solution and done. Precise Parts is greate. However, it will usually run you $100 plus. But that can be justified by a single perfect solutuon. But change anthing in the imaging train, and it more likely will no longer work. Lynn K. |
Chris at Overcast Observatory makes all kinds of spacers and shims.
Tony: aliexpress typically takes 2-3 weeks (for Europe)
Be careful with cheap adapters! I discovered that some of the cheaper adapters and extensions have the threads cut in a way result in the tube edges are not perfectly parallel with each other, which can result in tilt. I have two 33mm length, 48mm diameter extension tubes: one from Stellarvue and one cheap one. The cheap one produces tilt while the Stellarvue one does not
Blue Fireball has a decent parts CS Brian |
Be careful with cheap adapters! I discovered that some of the cheaper adapters and extensions have the threads cut in a way result in the tube edges are not perfectly parallel with each other, which can result in tilt. I have two 33mm length, 48mm diameter extension tubes: one from Stellarvue and one cheap one. The cheap one produces tilt while the Stellarvue one does not Noted, I have seen that as well. Really makes me wish I still had a machine shop where I could easily crank these things out as needed. |
