Flat panel from Deepskydad it flickering when it connected to the Eagle 5s Generic equipment discussions · Dumitru Irizan · ... · 2 · 80 · 0
Dimici19 0.00
Hello,
My flat panel from Deepskydad it flickering when it connected to the Eagle 5s.
I power it with 12V 3A from EAGLE 5S. When I power this flat panel independently of the Eagle, directly from a dedicated 12 V power supply, it works perfectly.
The Eagle is connected to a Bluetti battery that delivers a constant 13.3V. Has anyone had a similar situation? or does anyone know how I could fix the problem?
hbastro
Yes, not with that brand, but with other EL flat panels when they are under powered, ie. not enough power…
Dimici19 0.00
I realized this too, I tried changing the Eagle port output from 12V 3A to 12V 5A, and still no results. The voltage is not possible to change.
