I had posted this on facebook a while ago, built a power rig here for work and processing astro photos, thought I would post the build sheet that is actually pretty reasonable for what it can do. https://newegg.io/d2089eb Some real world astrophoto numbers with this setup. First, I just have a standard PIxInsight install and Astro PIxel Processor for stacking. I did RC Astro tools since that is usually a good gauge of speed and leveraging CUDA. APP Stacked (100) full frame 120Mb .fits images (Master Bias, Dark, Flat, and Bad Pixel Map used) = 6 minutes PixInsight I processed using the power of the Nvidia and get these times. Pix - NoiseX = 11.7 seconds Pix - BlurX correct only = 24.6 seconds Pix - BlurX full image = 20.2 seconds Pix - StarX = 53 seconds GradientCorrection = 3 seconds Fast... No overclocking here, in fact I have the video card throttled down to 90% for silent behavior. Entire setup could easily be overclocked though. I also could improve just by not using my older 4Tb disc drive and move to a SSD or PCIe for the astro photos. |
Oskari Nikkinen: Along the same lines as above, a nights work of over 1000 files usually stacks in Siril in under 15 min. I'm not sure how long it would take with your data but I'm sure it would be a lot faster. It might be a worthwhile compromise to save over $4000. |
+1 on building instead of buying. The savings are large but you also have the ability to choose the best reviewed parts yourself. I built one in the fall with a Ryzen 5950X, a 4080 super, an Asus Proart Mobo, 96 gigs of RAM and a couple of 4 Tb M.2 drives. Having that built would have been almost twice as much. The other reason for fast is that you are more likely to avoid pc intensive processes if your PC is not fast enough and one can use all the processes one can get sometimes. |
I was struggling with my Processing as well on my laptop….I bought a OMEN 45L gaming computer and cut my PI processing by 3/4 time what used to take an hour now takes 15-20min longest its taken even with a hundred 6200mm pro files and all associated bias, flats, darks Etc…. is 38min….I am super happy with my setup In my opinion and i firmly believe …..Time is the only thing we cannot buy….Buy COMPUTING SPEED it saves time and spend the money to do so you wont regret it!!! |
Jumping into this late. If you do get a 128Gbyte PC consider setting up a 64GByte ram disk for PI.
