Advice for a dual setup Generic equipment discussions · Francesco Ottonello · ... · 8 · 239 · 2
Ziofrancotto 0.00
I'm currently happy with my Redcat51+Asi 183MMPro and his FOV; I own a Sharpstar 65Q (65/420mm) that I don't use because of FOV with my CMOS.
I dream of building a dual setup to maximize the few nights I can go outside and for this reason I want to ask some advice.
If I buy a ASi 533 OSC+ a 135mm (Askar or Samyang) and use Redcat51+ASI183 for Luminance and Ha is a bad thing?
Or is a better thing but more expensive to buy a ASI 2600 OSC and use it with Sharpstar 65Q and RedCat51+ ASI 183 for luminance and Ha?
Keep the image scale as close as possible and have the OSC FOV overlapping the FOV of the mono sensor, that is my advice. Use astronomy tools to check the various possible combinations.
The 135mm aperture will have 7 times the light collection area of the RC51 and 2.5x the resolution. Apature wins in this size range. Adding data from the much smaller aperture won't gain you much. This is the main reason that dual rigs don't make a lot of sense for small OTAs, the efficiency just isn't there. Also, I can't see any profit in polluting the 135 data with the much lower resolution RC51 data.
WhooptieDo 10.40
He's talking about a Rokinon 135... not a 135mm refractor.     The Redcat outperforms the Roki here by a little bit, even though the Roki has a larger aperture.
Brian Puhl:
Ugg!
Brian Puhl:
*I very much don't think so if we are talking about efficiency.
Ziofrancotto 0.00
I've played a little with astronomytools.
Redcat51+ASI183 resolution 1.98"/pixel
Sharpstar 65Q+ ASI 533 1,85"/pixel
Which combination would be better for Luminance and which for RGB? As I know better Luminance with higher resolution
Ziofrancotto 0.00
Second option
Sharpstar 65Q+ASI 183 resolutionn 1.18"/pixel
Redcat51+ASi 533 resolution 3.1"/pixel
I think in this solution Sharpstar for Luminance is better and Redcat for RGB
The optimum combination is the first since they yield similar resolution and you can still feed the RGB into the luminance channel (or Ha/OIII if you use Dual NB) and still capture at the same time the Luminance (or Ha/OIII) signal. So you get the best of both worlds. In the other case the extra time or better SNR would be wasted for RGB because you'll have to spend a lot more time for L.
