Looking for someone who can carry out a photographic clarification of an object near Jupiter Electronically-Assisted Astronomy (EAA) · Bernhard Suntinger · ... · 12 · 672 · 2
UnendlicheWeiten 0.00
Hello everyone,
Last Sunday on a cold winter night I tried to position my mount precisely to the north. Since the Polar Star is not visible at my observation location, I tried an alignment on Jupiter. I was 6 degrees off from Jupiter and tried to bring the mount in using PlateSolve. I discovered a very noticeable object, which I originally thought it was a reflection of Jupiter. It was about the size of the Medusa Nebula and very noticeable with Hyperstar on the C11 with ASI2600 at 5 seconds exposure and auto histostretching in SharpCap. Unfortunately the weather is bad for my observation location for the next few days. This means I can't check exactly. There is no object noted in this area in Aladin.
Now I'm no longer sure whether it was just a reflection and would ask you to take a quick look.
The object was with my equipment in the same field of view as one of the listed objects. Unfortunately, I can no longer say exactly which object.
Either: NGC 927, IC 222, NGC 990, IC 238, NGC 1024
I would be very grateful if someone could briefly check these objects to see if the object I mentioned is in the same field of view.
Request for feedback.
Kind regards,
Bernd from Austria
spacetimepictures 4.82
Hi sure. Could you share coordinates?
I can make you a short integration in L tonight and post it here (in approx 12 hours). Focal length is 530mm (Epsilon 160ed), full frame sensor.
The only reasonably bright object within 6 degrees (in RA) was 144P/Kushida. NGC821 is also a possible but much fainter candidate.
Oh great. Thank you very muchsmile
I was traveling in this area of ​​the sky when I noticed the object.
If you could take photos of these coordinates, the object I described should be visible (unless it was just a reflection).
NGC 1024 (RA 02h 40m 30.4s / DEC +10° 57' 05")
NGC 990   (RA 02h 37m 36.8s / DEC +11° 44' 49")
NGC 975   (RA 02h 34m 40.5s / DEC + 9° 42' 30")
IC 222       (RA 02h 23m 59.6s / DEC +11° 44' 14")
I'm really excited to see if you find anything in the pictures…
Clear skies
Bernhard Suntinger:
I'm really excited to see if you find anything in the pictures...
Clear skies
Ok, I will do a 3 panel mosaic of the area tonight. I'll post results here when ready, around noon tomorrow.
Only could do two panels!
Each is 16*60s of L at gain 100, ASI6200MM + E160ed; calibrated/stacked/STF :
https://www.astrobin.com/mm8zs1/
https://www.astrobin.com/ag26ww/
Big diffusion halo around Jupiter!...
I'll let you check on https://nova.astrometry.net/upload for identification
Cheers
Laurent - SP
Thank you very much!
Yes, i think this was the object I´ve seen last Sunday.
It is in the same area I´ve described above.
Can someone help me and give me tips on how to proceed here?
Could you highlight which object you are talking about ?
Unfortunately, false alarm. I suspect Jupiter just cheated his way into the picture here.
@Spacetime Pictures  Thank you very much for the clarification.
Unfortunately, the object I described is not visible in your two photos. I suspect that I only saw a reflection of Jupiter back then. Thank you again for your efforts.
Next time maybe! You're welcomesmile
So, the mystery of the strange object near IC222 has now finally been solved!!
It's just a dominant light reflection from my f2 hyperstar system, which only appears so prominently in exactly this area of ​​the image.
Optics are weird smile
