Has anyone seen anything like this before in flat frames? This is a single flat with an STF applied and I have these speckles on one side of the sensor. I've tried a number of different exposure lengths as well as twilight flats and using a flat panel.  |
Looks indeed like condensation on your sensor. If you look closely, you will probably find them on your lights as well. Turn off cooling for a bit, until they're gone. Then turn cooling back on but try to cool down very slowly.
Willem Jan Drijfhout: Looks indeed like condensation on your sensor. If you look closely, you will probably find them on your lights as well. Turn off cooling for a bit, until they're gone. Then turn cooling back on but try to cool down very slowly. Indeed and alternatively, letting the camera stabilize at its cool down temperature for 15-30 minutes before imaging can help with icing.
That's it thanks guys. It was dew. problem solved.
