Homofocal filters not genuinely homofocal [Deep Sky] Acquisition techniques · Markus Ohlig · ... · 4 · 212 · 0
MarkusPaul 0.00
I have a set of homofocal LRGB filters from Astronomik and a set of homofocal narrowband filters each from Baader and Askar. When focusing for example with the Astronomik R filter using a Bathinov mask, the other Baader L,G and B filters are slightly out of focus.
Same thing with Baader H and O and with Askar H and O while S is aligned with H.
Anyone come across this issue that homofocal filters are not genuinely homofocal? I am using a TS 121Optics Quindruplet APO with f/5.6.
JanvalFoto 4.51
I think this is quite normal. My Antlia filters are parfocal as well, but there is still some shift between them. Doesn't matter when I take flats, but it is noticeable during sub exposures if I don't refocus between each filter swap. It's been manageable on comets where I don't refocus after focusing with L, but I wouldn't advice it on regular DSO's.
Most filters have some minor room for error which should be specified by the maker, for mine the error is about 0.05mm. Also temperature shifting will affect the optics and thus affecting your focus. As long as the filters are the same thickness that is what's most important as that will affect your backfocus distance.
When using NINA you could work around this by using filter offsets, with the Asiair you cannot though. I think generally filters are called parfocal if they are of equal thickness, but actual parfocality depends on your entire system as some optical systems focus the color wavelengths at a slightly different position. I think at least optical instruments using lenses, like refractors or regular lenses, are especially susceptible to this due to residual chromatic dispersion and are unable to focus all the wavelengths at the same position - although it can be pretty close.
That's spot on, between color correction in the optics and slight differences between filters, you will still need offsets. Everything is critical at F/5.6
jwillson 3.66
Even if your filters are perfectly parfocal (and they probably aren’t) your telescope won’t be. You’ll need to focus after switching filters and/or use a filter offset.
StewartWilliam 5.21
Sorry, but what does homofocal mean, is that the same as parfocal…??
