A few weeks ago (not to say months or "ages"), I changed my main imaging camera. I swapped my trusted ASI294MC Pro for a Touptek 2600mm. I ran some test and the camera appears to work fine. However, I have persisting star shape issues since I move to this camera. In short, I have unsatisfactory stars accross the field, but with a pattern that does not clearly suggest bad guiding, bad collimation, bad BF or tilt. I am bit lost here and I would like to gather some qualified opinions.
Please find the abberation inspector frames of two 600s subframes with my Ha and Oiii filters.
Both were taken tonight a few minutes appart, with my 200/800 f4 newtonian, my touptek 2600mm, an OAG with an ASI120mm, all of that on my EQ6r Pro. Note that guiding was below 0.7'' at anytime (tonight sky is not better than that but that's ok). With good conditions, I get down to 0.35''.
Any insight would be much apprectiated.
EDIT 1 : I replaced the mosaic by one where the Ha and the Oiii have the same orientation.
EDIT 2: Here is a mosaic of a 1 hours stack, nothing done except gradient extract.
Patrice
