Gain vs light pollution vs full well? [Deep Sky] Acquisition techniques · Sean Mc · ... · 4 · 270 · 0
smcx 3.61
Preface:  I pretty much exclusively use AI to search these days, but I still don’t trust it lol.
AI is telling me that a gain of 200-300 would be beneficial under my light polluted skies with the asi294mm pro. For nebula, not stars.
Anyone want to take a stab at explaining that one?
I mean other than “i just use unity gain”.
thx!
Rustyd100 5.76
Severak cameras today have their optimum gain setting at 100 instead of unity (zero). That being said, I’ve shot several targets at 300 with good results. With enough subs, the noise is mitigated and brighter targets usually look about the same either way.
smcx 3.61
The question is… increasing gain will increase the “noise” from light pollution too won’t it?
or…
will shooting Ha/OIII mitigate the light pollution enough that increased gain will be beneficial in light polluted skies?
completely remove star saturation from the question, I’m only asking about faint fuzzies and emission nebulae.
AI seems to think that increased gain will be helpful as I can shorten my exposure time which will decrease the effect of light pollution. I’m not sure I agree.
neverfox 3.32
That's the exact opposite of what you should do. The more light pollution, the less read noise is a factor and the more full well matters, as the LP takes care of both swamping read noise and filling up your pixels with unwanted signal, meaning you should tend to favor lowering your gain. High gain trades off full well for lower read noise. When you start getting into these high gains with trivial read noise, you're just throwing away dynamic range for no good reason in the worst possible context. In any case, there's never a good reason to go higher than 120 on that camera in Bin 2 mode because it's not efficient in the trade-off. The only other gain to consider is the gain 0. Which you choose really requires a decision about what the minimum sub length you're willing to take is (e.g. perhaps you can't or don't want to process the number of subs that 120 would give you with the shorter subs it calls for, taking it out of the running). In Bin 1 mode, gain 0 is the only gain you should consider. It's fairly easy to determine potential candidates for gain: look at the dynamic range chart for the camera and look for the gains where it has maximum potential. Ignore all others. And never "just use unity gain". It's just a gain where 1 e- = 1 ADU. Unless your goal is to count electrons without a conversion factor, it's worthless as a guide to optimized subs. The only time you should be using unity gain is if it just so happens to be one of those gains where DR is potentially maximized.
LLM "AI", fwiw, is just a stochastic parrot. It doesn't know anything. I might broaden your search resources, as you did in coming here.
HegAstro 14.24
What Roman said is exactly correct. The noise from light pollution only depends on the number of photons incident. The only thing that gain is doing is increasing both signal and noise BY THE SAME AMOUNT so that the SNR is unaffected. On the other side, increasing gain is reducing dynamic range by decreasing the full well capacity. You are gaining nothing by operating at high gain (meaning above 120 in bin 2 mode) and losing full well capacity. It is a bad trade off with no upside. AI in this case may be artificial but it is certainly not intelligent. The overcoming of noise (other than read noise and fixed pattern noise) by gathering more signal depends only on total exposure time, not sub exposure time and number of subexposures.
