Flats, does this look right? [Deep Sky] Acquisition techniques · Josh Wilkinson · ... · 9 · 361 · 5
joshwilkinson60 0.00
I am new to astrophotography. I use ASIAIR for acquisition, I have an ASI533MC Pro. When I go to take flats using the auto exposure setting, the flats always have this pattern, see images here, you may have to zoom in to see, I have tried to point out issue: -
Screenshot_20240910-194640-EDIT.jpgScreenshot_20240910-194640.pngScreenshot_20240910-194703-EDIT.jpgScreenshot_20240910-194703.png
I have tied with an iPad screen and a T-shirt into a soft illuminated white wall, same pattern shows.
After preprocessing I see the pattern come through to the lights. Without the flats the issue goes away
Is this expected? Is this an acquisition problem, or a hardware problem, or a preprocessing problem?
Any help here is greatly appreciated
Thanks
It's not a problem with how you are illuminating your flats. Something is happening at the pixel level. I'm sure someone here will have seen this before….
AstroÅmazer 0.00
How are you stacking the flats? How many are you taking? For example, in DSS, I have had more success with Median with < 32 flats and with Median with Sigma Kappa Clipping with > 32.
Are you taking dark flats? Or using bias frames?
Also look at your hot pixel rejection settings and raw conversion settings.
Turn cooler off and see if the pattern change.
AstroÅmazer:
I have tried with both dark flats and just bias, same result, I have seen oddness in DSS, I am now using WBPP so I will try and play with some settings in there to see if I can track down the issue, thanks for the reply
I will give that a go and let you know the result, thanks for the reply
frankz 4.07
I agree with Andrea – what you are seeing is light refracted by ice crystals!
@andrea tasselli I gave this a go without cooling and I got a much better result
frankz 4.07
Then it’s indeed ice. You can try by not pushing the cooling too much (0 C is enough for most modern cameras), and slowing down the rate of cooling. Or, of course, you can try to fix it by removing the moisture from the sensor chamber with new desiccant tablets.
guidohaak 0.00
I concur that this is ice. Cool down more slowly. In NINA give it a minimum cool-down time. You can also do this manually by decreasing in 2 degree steps. Control the cooling process by making regular exposures. If there is already ice then warm up a bit and recool. You can also just wait for a while till the ice is gone.
