Askar C1/C2 vs D1/D2 filter set... which one?? [Deep Sky] Acquisition techniques · peng155 · ... · 3 · 297 · 0
1.20
(deleted)
IMO,
I think it's risky to use any of those with the Hyperstar (besides the IDAS)
the IDAS was especially designed for fast systems
if you want SII, I can only recommend getting an Astronomik MaxFR SII
I may not be remembering if there is a fast FR dual band OIII/SII filter, but if there is, I'm sure someone will point it out
and yes, narrower filters will give you better contrast; the narrower the better
Alexn 12.25
D1/D2 are SIGNIFICANTLY better than C1/C2, however, you will get bandpass shift using them on a hyperstar or rasa…
I'm in bortle 5 and the difference between my d1 and the c1 I used to use is wild.
(deleted)
