Hi folks, these days I tried to capture NGC2276, near the northern celestial pole. ASIAIR worked fine for PA and all other routines but failed to center NGC2276. Theplate solving ended after 1 second and no failure was mentioned. The only problem was that NGC 2276 was nearly half of the frame off. I corrected framing manually and the sequence run perfect until clouds came up. After a while the sky cleared up and obviousley ASIAIR recentered the frame to the FOV before my manually corrected FOV, all following frames were trash :-(. Now my question, has nayone had similar issues? Thanks in advance and CS Frank |
well I had issues with the NCP, with some similarity: I tried to Goto Polaris, but I was always slewing to a place near it (the NCP I guess?) and never centering the actual star; I had to manually center it through the app then I tried to calibrate guiding, but that wasn't working; star wasn't moving enough; I had to change the Calibration Step (I think it was that) to a longer duration then when guiding calibration was complete, I tried guiding, and the guiding was horrible, so I gave up on Polaris you might ask why I wanted guiding, well, I guess my PA was bad (which doesn't make sense, because my PAs are always under an arc minute in either axis); my mount was perpetually drifting one way and so if I just stuck to tracking, then the target would go out of FOV within a half hour probably |
