I recently became aware that the airy disc size on my TOA-130 telescope in green light is ~10.5 µm. (In fact, the airy disc size is only governed by f-ratio so all F7.7 telescopes will have this airy disc size regardless of their aperture).
When I calculate how much of the sky that airy disc covers it comes out to 2.18" with the TOA + 645 flattener.
When I go checkout the spot diagrams of the Takahashi 645 flattener I find 1 µm spots RMS on-axis and 2 µm RMS at full-frame.
https://www.cloudynights.com/topic/822975-toa-130-toa-150-and-645-flattener-results/
What I don't understand is why are this super small spots prized when the airy disc is 5x - 10x larger?
Also, the TOA is known for being a super sharp telescope but how can that be when it's airy disc is so much bigger than what's you get with say a RASA 11 with <4.4 µm RMS spots with and airy of 2.96 µm.
https://www.celestron.de/media/mageworx/downloads/attachment/file/1411/RASA_BOOKLET_11in_36cm_2018_LR.pdf
While the RASA the optics are not diffraction limited (what you see is governed by the RMS performance instead of the airy disc) but even then it has 50% better resolution than the TOA-130... [1.46" * 1.49 = 2.18"]
I must be missing something because I don't see a lot of people reaching for a RASA during galaxy season even though these numbers seem to suggest it has significantly better resolution.
What am I missing?
