Why can't I plate solve this image in PixInsight? [Deep Sky] Processing techniques · AmyWarble · ... · 6 · 307 · 0
warble_master 12.34
I captured this 4 nights ago (on 4/13/2025), but no matter what I do, I can't plate solve it in PixInsight.  I am using my local GAIA DR3 database files.  My focal length is 840mm and pixel size is 3.76 μm.  My GPS coordinates are approximately 86W by 35N.
Astrometry.net solved it in 4 seconds: https://nova.astrometry.net/user_images/12422025#annotated
This link is the full XISF file with my GPS coordinates removed:
https://www.dropbox.com/scl/fi/du426kcy9z2ahuzj1yrsi/masterLight_BIN-1_6248x4176_EXPOSURE-120.00s_FILTER-Green_mono_autocrop.xisf?rlkey=b8o75zn0rvdfheu0r8qolmxxm&st=1t4h44v1&dl=0
What do I need to do in PixInsight to plate solve this?  I've tried noise reduction and gradient removal, but nothing works.  I captured LRGB and none of them can be plate solved, and I don't know why.
Processing script file: C:/Program Files/PixInsight/src/scripts/AdP/ImageSolver.js
* Code signature verified:
script-id : ImageSolver
developer-id : PTeam
timestamp : 2025-04-02T16:51:57.069Z
Detecting stars: 100%
1764 stars found
DynamicPSF: Global context
1 view(s)
1764 star(s)
1763 PSF fittings
149.177 ms
* Removed 12 conflicting sources (0.69 %)
* Search quadtree generated with 1751 objects, 21 node(s), height = 3
* Star matching tolerance: 2 px
Gaia: Global context
4.200 us
Searching for optimal magnitude limit. Target: 2205 stars
136.089 ms
m = 13.34, 50 stars
309.465 ms
m = 19.47, 548 stars
314.046 ms
m = 22.53, 549 stars
341.802 ms
m = 24.06, 549 stars
366.903 ms
m = 24.82, 549 stars
349.207 ms
m = 25.21, 549 stars
308.206 ms
m = 25.40, 549 stars
338.869 ms
m = 25.49, 549 stars
328.318 ms
m = 25.54, 549 stars
 * Using an automatically calculated limit magnitude of 25.54.
Seed parameters for plate solving:
Center coordinates: RA = 11 20 15.664, Dec = +13 35 28.50
Resolution: 0.923 as/px
Executing Gaia DR3 search command…
1523 sources found.
322.592 ms
Catalog Gaia DR3 (XPSD): 1523 objects.
StarAlignment: Processing view: integration_autocrop2
C:/Users/amywarble/AppData/Local/Temp/stars-001.csv:
Scanning star data: done
153 stars.
integration_autocrop2:
Structure map: done
Detecting stars: done
1767 stars found.
Minimum star size: 3 px
* Computing global linear transformation.
* Target image: limiting to 191 brightest stars.
Matching stars: done
77 putative star pair matches.
Performing RANSAC: done
** RANSAC: Unable to find a valid set of star pair matches.
* Previous attempt failed - this is try #2
* Previous attempt failed - this is try #3
* Reference image: limiting to 125 brightest stars.
* Target image: limiting to 125 brightest stars.
45 putative star pair matches.
* Previous attempt failed - this is try #4
* Reference image: limiting to 60 brightest stars.
* Target image: limiting to 60 brightest stars.
11 putative star pair matches.
* Previous attempt failed - this is try #5
* Reference image: limiting to 30 brightest stars.
* Target image: limiting to 30 brightest stars.
** 0 star pair matches found - need at least 3 matched stars.
* Previous attempt failed - this is try #6
* Reference image: limiting to 15 brightest stars.
* Target image: limiting to 15 brightest stars.
* Previous attempt failed - this is try #7
* Reference image: limiting to 8 brightest stars.
* Target image: limiting to 8 brightest stars.
* Previous attempt failed - this is try #8
* Previous attempt failed - this is try #9
*** Error: Unable to find an initial linear transformation.
<* failed *>
* Previous attempt failed - trying with mirrored reference coordinates.
1523 sources found.
324.774 ms
153 stars.
Structure map: done
1767 stars found.
75 putative star pair matches.
53 putative star pair matches.
14 putative star pair matches.
<* failed *>
* Previous attempts failed - trying again assuming apparent coordinates.
1552 sources found.
315.369 ms
Catalog Gaia DR3 (XPSD): 1552 objects.
187 stars.
Structure map: done
1767 stars found.
* Target image: limiting to 233 brightest stars.
73 putative star pair matches.
52 putative star pair matches.
<* failed *>
1552 sources found.
325.784 ms
187 stars.
Structure map: done
1767 stars found.
71 putative star pair matches.
62 putative star pair matches.
12 putative star pair matches.
<* failed *>
*** Error: The image could not be aligned with the reference star field.
Please check the following items:
    The initial center coordinates should be inside the image.
   The initial image resolution should be within a factor of 2 from the correct value.
   If you use an online star catalog through the VizieR service, consider using the Gaia DR3 catalog with local XPSD databases instead.
   If the image has extreme noise levels, bad tracking, or is poorly focused, you may need to adjust some star detection parameters.
Die_Launische_Diva 11.54
It solved instantly on my end:
* Convergence reached after 2 iterations.
Saving keywords...
Saving properties...
Creation time ............ 2025-04-17 06:11:50 UTC
Creation software ........ PixInsight 1.8.9-3 / ImageSolver 6.2.12 (Windows)
Reference catalog ........ Gaia DR3
Linear transformation matrix (world[ra,dec] = matrix * image[x,y]):
+3.30854228e-05 -2.55082144e-04 +4.12712533e-01
+2.55042685e-04 +3.30838757e-05 -8.57983313e-01
WCS transformation ....... Thin plate spline
Control points ........... 799
Spline lengths ........... l:799 b:799 X:799 Y:799
Projection ............... Gnomonic
Projection origin ........ [3102.005453 2020.304863] px -> [RA: 11 20 19.646 Dec: +13 35 28.26]
Resolution ............... 0.926 arcsec/px
Rotation ................. 97.386 deg
Reference system ......... ICRS
Observation start time ... 2025-04-13 04:40:34 UTC
Observation end time ..... 2025-04-13 05:52:57 UTC
Geodetic coordinates ..... 86 57 12 W 35 30 23 N 209 m
Focal distance ........... 837.61 mm
Pixel size ............... 3.76 um
Field of view ............ 1d 35' 44.4" x 1d 2' 21.6"
Image center ............. RA: 11 20 19.647 Dec: +13 35 28.26 ex: +0.000011 px ey: +0.000018 px
Image bounds:
top-left .............. RA: 11 22 00.936 Dec: +12 44 03.44 ex: -1.717340 px ey: -1.179296 px
top-right ............. RA: 11 22 52.354 Dec: +14 18 49.17 ex: +0.111994 px ey: -1.099000 px
bottom-left ........... RA: 11 17 47.683 Dec: +12 52 02.14 ex: -1.098729 px ey: +0.000375 px
bottom-right .......... RA: 11 18 37.465 Dec: +14 26 51.79 ex: +0.111409 px ey: +0.000304 px
Maybe something is wrong with your local Gaia DR3/SP setup?
warble_master 12.34
I… guess?  I can plate solve other images.  Just not this target.
warble_master 12.34
I'll re-download my GAIA database files and see if that makes any difference.
warble_master 12.34
That did it.  I'm not sure what happened but re-downloading the entire GAIA database did the trick.
Bennich 5.02
I often see that the Gaia files need to be “re-configured” in the Gaia script. I keep my gaia files on an external drive, and if the disk is not correctly dismounted, then I see similar errors to what’s described above.
I have never had to redownload - just “re-configure”.
Great that you’ve solved your problem 👍
Astromon 0.00
This master image also can't be plate-solved. Trying all inputs, but it does not work. Help needed thanks.  https://drive.google.com/file/d/17suvnRndA8O5DFQysIVCsAlthYH3nBMZ/view?usp=sharing
