processing twin setup data question [Deep Sky] Processing techniques · James · ... · 4 · 202 · 0
jamesmdmad 0.00
Hi all ,
I have a twin setup, 2 esprit80 on the same mount , one with Oregon 571 Mono with L R G B Ha Oiii Sii filters  and the other with with Oregon 571 Color with L  and Ultimate  filter .
I usually shoot  RGB on color and L on the mono , that’s straight forward .
The other normal situation is Ultimate on the color and Ha. Oiii Siii on the mono .
so , what’s the best way to integrate NB from both cameras ?  Ha from color and Ha from Mono .
Is there a  way to stack from beginning ?
Thanks  in advance .
James
TareqPhoto 2.94
James:
Hi all ,
so , what’s the bes way to integrate NB from both cameras ?  Ha from color and Ha from Mono .
Thanks  in advance .
James
I kinda spent years to make those kind of setup, first it was a dual setup in my plan or mind, suddenly that became like three or four setup, but nevertheless, even if i used a dual setup like yours, i wasn't thinking about having same data from both, i mean use the mono for SHOL and use the color for RGB, if you are under Bortle 1-5 i think the color will give you good enough RGB signal, why you occupy it with narrowband as well?
Maybe if you are in hurry under dark sky you can try using the color with the dual band, i have only one color camera and i have L-Ultimate, but i also have Ha and SII filters 2", i might add OIII later, then L-Ultimate could be pointless unless if i use it under darker sky for quick imaging, but i am planning to use it for RGB only.
jamesmdmad 0.00
Tareq Abdulla:
James:
Hi all ,
Thanks  in advance .
James
Hi , thanks ,
The setup is working fine for me , I was wondering how to get the most out of NB data trying to stack Ha from mono with the Ha from the ultimate filter on the red channel of the color camera for example
daniele.borsari 5.25
What I did for my latest image of the veil nebula was to prepare both color and mono data (DBE and BlurXTerminator on each master light) and than extract the Ha and Oiii from the color master using DBXtract.
I ended up having 4 mono images (real Ha, extracted Ha, real Oiii and extracted Oiii). I blended the real and extracted mono images with ImageIntegration (it needs at least 3 images so I added them twice) using SNR as weighting factor and no pixel rejection.
To sum up:
Ha mono master > DBE, BXT > RealHa
Color master > DBE, BXT, DBXtract > ExtractedHa
ImageIntegration (RealHa, RealHa, ExtractedHa, ExtractedHa) > CombinedHa
Do the same thing for Oiii.
Daniele
jamesmdmad 0.00
Daniele Borsari:
To sum up:
Daniele
Thanks Daniele , yes,  that’s what I’m doing now .
I wondered if there is  a “ fast “ way to stack them from beginning .
I would have to calibrate all  lights , then debayer , then split to R G and B , and after all that, stack all of them  with de original mono files , .
But….. it’s a lot of processing and time and space .
ill stick to what we are doing now I bet .
thamks
James
