Neutral Background Color (Black) [Deep Sky] Processing techniques · Anderl · ... · 16 · 666 · 0
Anderl 4.52
Hello fellow Astro Friends,
i am at this point 4 years? into taking and processing deep sky pictures as an hobby, a thing that is a constant trouble for me is archiving an optically pleasing background.
my processing is an almost boring process. after using spcc I try my best not to mess with the color balance of the image, but the steps of stretching, saturation etc. are almost always led to an unpleasant background color. my pictures tend to get an either green or blue color cast as soon as I push my data.
right now I am dealing with it by using color masks in photoshop with the aim of only reducing the background saturation.
do you guys have any tips on how to better deal with that problem? is there anything I can do earlier in the process within pixinsight?
cs
anderl
Fibo1 0.00
Hi Anderl,
can you please list your process sequence steps which you apply? Else, it is difficult to help you.
Hubert
Anderl 4.52
Hi Anderl,
Hubert
Servus Hubert,
- stacking
- gradient correction
- blur x
- channel combination
- spcc
- star x
- stretching of starless/stars
- color saturation
- recombination of stars and starless
- final adjustments
Thats more or less my workflow
cs
anderl
Without a practical example is hard to tell.
Fibo1 0.00
Servus Anderl (aus Österreich??),
just a question: you do stretching after star x, thus you do stretching twice: one time for starless version and one time for the stars??
My steps are (OSC frames from my DSLR):
- stacking
- channel extraction
- linear fit
- dynamic crop
- script "autocolor" from PixInsight Austria (I use it instead of SPCC, as it is very fast and the results are pleasing me)
- SCNR
- NoiseXterminator
- script "DeLinear" from PixInsight Austria (works fine for me in almost all cases so far)
- Starnet2  -> CurvesTransformation for the starless image plus gradually ColorSaturation, a little bit of CurvesTransformation also for the stars
- final adjustments in Photoshop Lightroom
with this workflow I never ever had any issues of color shifting so far
CS Hubert
Anderl 4.52
Hey andrea,
https://astrob.in/08fji5/0/
The picture had a noticeable green color cast in the background area as well as in the weaker nebula parts. This is the picture after i reduced the background saturation in photoshop.
- stacking
- linear fit
- dynamic crop
- SCNR
- NoiseXterminator
CS Hubert
Thx for sharing your workflow hubert!
almost Austria 😄 lower Bavaria near passau.
am i wrong if i assume that i shouldn’t use scnr after spcc?
Anderl:
Hey andrea,
*I can't see much of a green cast in the BG or in fact anywhere else. Except for the green halos around most of the stars that is. What I was looking for is an example before correction in PS is made.
Anderl 4.52
Anderl:
Hey andrea,
Thx for taking look andrea. I sadly don’t have such an example rn. I will post one as soon as i have time to process something.
I think the green halo around the brighter stars is a good example for the green cast. The halo areas around the stars seems bright enough to not be affected by the masking i do in photoshop.
Fibo1 0.00
Anderl:
SCNR removes any removing green cast. As most astronomical objects (except stars, galaxies, planets and moons) do not have any green color, removing any residual green touch makes normally sense, if there is any. I do not use it "full scale", but apply it reduced to the level of about 50 to maximum of 80%, if it seems to be necessary. According to the guidelines I follow I do apply it after color correction. Taken this in account, a replacement of my color correction process by SPCC  would mean that SCNR would then be applied after SPCC
Hubert
SCNR should be applied to the stretched image and then only up to 50%.
Anderl:
*I think that is most likely self-inflicted in the sense that it goes with the processing. A different take on the stretching would likely lead to more acceptable results. And SCNR can be applied to the stretched starless image, with some moderation maybe in conjunction of using masks. Again, the only way to test this is by doing it differently or having someone else do it and see what is the outcome.
Anderl 4.52
Anderl:
Not that i doubt that but my assumption was that one should not mess with anything throwing off the color calibration after using spcc?
i am only doing linked stretched after spcc and if i increase the saturation i also increase the overall saturation, this also includes not using scnr after spcc.
Once stretched you can apply SCNR without affecting the overall color balance. Moderation in color saturation in relation to the SNR is they key word here. As we used to say: "respect the light".
whwang 15.16
In the example image, there are red nebulas everywhere.  I believe you can get Ha emission from every single pixel if you go deep enough.  Under this circumstance, any algorithm will have problems finding Ha-free regions to evaluation the "true background" (there is no true-background).  So if the algorithm uses some areas with faint Ha emission as background, it will over-subtract the red, leaving a cyan tint in the "background" region.
I see such effects all the time in my images with large nebulas. I don't think this can be avoided. You have to rely on your own judgement to compensate this is post processing.  This becomes art, not science.
Anderl 4.52
Wei-Hao Wang:
Thx wei-hao,
makes sense.
cs
anderl
AstroReghe 1.20
Hi Anderl.
I haven't seen all the answers but I have seen your workflow.
I strongly suggest you to use blur x terminator in # correct only# mode before color calibration.
Afterwards you have to use blur x terminator in # sharpen stars mode and not stars#.
Altering the PSF does not allow for correct color calibration
I also recommend you to use a DBE on the single monochrome channels and then use linear fit between R-G-B
because of the green color cast, as @andrea tasselli  says, SCNR should be used to make the background color uniform and never at 100%.
If you have a green cast only in some areas, you can create a mask with the @Adam Block  GAME script and remove the green in those areas partially
Riccardo
alpheratz06 0.00
Anderl:
cs
anderl
Hello
I don't know if this can help, but, when I have a non neutral background residual on the final picture, I just clip the left side of the histogram with GIMP for instance in LRGB mode, to "push" the background to black
cheers
