Hi, see the second post there: https://pixinsight.com/forum/index.php?threads/wbpp-ignores-exposure-tolerance.17768/ In your case you might want to set the tolerance to 200 seconds or higher. |
Habib Sekha: Thank you Habib. Just curious, what method do you use to arrive at the recommended Exposure Tolerance? I'd like to understand how to determine that value for future stacking projects. After experimenting, I'm guessing I raise the value until all the subs combine into a single post-calibration line? |
Increasing your tolerance until they become one will work, or subtract your shortest exposure from your longest will give you the amount you need.
TDAbbotts:Habib Sekha: You’re welcome, TDAbbotts! In this particular case the longest exp time is 300s and the shortest 120s. The difference is 300-120 = 180s. Add to it “some” like 20 seconds. This gives the 200s. If they would have bern say 600s and 120s. The difference would have been 480s and then some like 20s giving 500s for the Exposure Tolerance. HTH 😊 |
Thank you to everyone who helped explain this to me!! You all are amazing!
