Is There Any Method To Get Rid Of Artifacts? [Deep Sky] Processing techniques · Szijártó Áron · ... · 12 · 309 · 0
Arons.2001
[url=http://Unprocessed Image Of Andromeda Galaxy https://imgur.com/a/98IUK1g]Unprocessed Image Of Andromeda Galaxy https://imgur.com/a/98IUK1g[/url]
Hello and welcome. I'd like to ask everyone who is using Seastar or any method to get rid of all of the artefacts in their deep sky images. I have a pretty good image I made with my seastar of the Andromeda galaxy with 2 additional galaxies besides it, which is likely want to keep. I tried to remove the gradient and the noise from the image, but I got a problem. Even if I cropped it, a small chunk of artefacts was still left in the image, and I do not know how to get rid of them l. Does anyone experienced this too, or know a method how to get rid of them?
DalePenkala 19.38
Szijártó Áron:
Hello,
I don’t use that software, but I’d suggest posting an image so that others can see what your problem is. This will help others to understand what you’re referring to.
Arons.2001
Dale Penkala:
Szijártó Áron:
Hello,
I use Siril, but sometimes Graxpert to get better images. And what is the problem is that m, as U can  see at the upper corner there is a chunk of artefacts left even after denoising? And I don't know how to deal with that.
JanvalFoto 4.51
There's still no image for us to review here. Before that we would only be wildly guessing I'm afraid.
Arons.2001
There's still no image for us to review here. Before that, we would only be wildly guessing, I'm afraid.
Can't show it cause the Image is too large; only 1mb is the maximum. But I describe it. The image includes the main galaxy with 2 galaxies beside it. And I managed to crop a huge part of the artefacts but there are still small artefacts left in the upper right corner and the bottom right corner. The Image would look good cause no noise is in the image, but these artefacts are unremovable. Even if I use good software for it, it doesn't get rid of it.
JanvalFoto 4.51
Yes, but to see what kind of artefacts we are talking about we need to see them. Artefacts can be a number of things and in order to see if it's possible to deal with them or determine what they actually are - we need a lot more than just the word "artefacts". Have you tried making a screenshot of an area of your image? You could also upload it to your gallery which should be the simplest solution.
Habib_Sekha 1.51
@Szijártó Áron  is this the picture you tried to post to show?
If that's the picture, you're looking at a stacking artifact.   A place in the image where not all the captured fames overlap. All you can do is crop it out.
Arons.2001
If that's the picture, you're looking at a stacking artefact.   A place in the image where not all the captured frames overlap. All you can do is crop it out.
To be honest, I already cropped the image, but the problem is that it's, not a thin stacking artefact that is simple to crop out; it's a big one and almost reached one of the objects I am trying to keep in the image.
Arons.2001
Habib Sekha:
Actually yes. That's what I'm trying to show, but I couldn't upload it here fully due to the size. U can see in the upper and bottom corners, there are still artefacts that I couldn't crop out of the image. They weren't too thin to crop out.
JanvalFoto 4.51
This is field rotation and is just one of the major drawbacks the Seestar has unfortunately. Not much can be done with it I'm afraid.
TiffsAndAstro 1.81
You could try stacking in siril I think it has field rotation support, but, unless you try and eq wedge and polar aligning approach with the seastar not a lot you can do about it
Szijártó Áron:
as the others above have said, this is caused by field rotation. Even though the SeeStar tracks the sky, because it's not equatorially mounted, it's view of the object rotates over time. Because of this, there are areas of the images that are not common to all frames. The longer your total exposure is, the more of this artifact you will see. Until someone builds a smart telescope with a field rotator, the only thing you can do is mount the entire unit equatorially, if that's even possible?
