How To Fix The Script Failure In Siril? [Deep Sky] Processing techniques · Szijártó Áron · ... · 6 · 172 · 3
Arons.2001
Hello and welcome. I'd like to ask everyone here who uses Siril to preprocess their astrophotography images. Does anyone come across such script failure that even if i use fits files which the software uses, the software still fails the Script? I even made the right directory for the software to use and got the right preprocessing data since I have a Seastar device. Then, I got this error failure message every time I tried to run the Script. I even tried an alternative solution didn't work. What do I do in this case?
daywalker
iT May be better to copy and paste the error rather than take a photo,so the whole error message can be read.
Which siril script are you using?
You should be using one of the osc scripts,not a mono one..
lock042 16.66
Szijártó Áron:
Your screenshot is terrible.... Fortunatly, the error is very common. You probably mixed format file (JPG and FITS) in the input folders.
Arons.2001
Cyril Richard:
Szijártó Áron:
Hello and welcome. I'd like to ask everyone here who uses Siril to preprocess their astrophotography images. Does anyone come across such script failure that even if I use the files which the software uses, the software still fails the Script? I even made the right directory for the software to use and got the right preprocessing data since I have a Seastar device. Then, I got this error failure message every time I tried to run the Script. I even tried an alternative solution didn't work. What do I do in this case?
Your screenshot is terrible.... Fortunately, the error is very common. You probably mixed format files (JPG and FITS) in the input folders.
 YEAH Lately before I used JPG as well for some reason, I didn't know it just targets one file. Is there a way to prevent this from happening or its like a software issue that the newer version cant recognized the file or WHAT?
Arons.2001
It May be better to copy and paste the error rather than take a photo, so the whole error message can be read.
I useing the Seastar Processing script since I have the device and using it.
 But thats what it says.
13:36:07: Filter Pattern: GRBG
13:36:08: Saving FITS: file pp_light_00228.fit, 3 layer (8), 1080x1920 pixels, 32 bits
13:36:13: Reading FITS: file light_00232.fit, 3 layer(s), 1080x1920 pixels, 32 bits
13:36:13: Image #231: number of layers (3) 19 not consistent with sequence (1), aborting
13:36:14: Reading FITS: f1le light_00231.fit, 3 layer(s), 1080x1920 pixels, 32 bits
13:36:14: Image #230: number of layers (3) i9 not consistent with sequence (1), aborting
13:36:14: Sequence processing failed.
13:36:14: Setting CND (Curent ₩orking Directory) To 'E: Vstzo\seastar\M33"
Those are the last messages that happens at the end of the Script. I tried every posibble way to get around it, didnt worked.
So im left disorianteted. Unless if anyone know a method to trick the system or what.
lock042 16.66
It's not a bug. You should read the tutorial for seestar on the website. It explains everything.
https://siril.org/2024/03/new-zwo-seestar-script-and-tutorial/
