Help needed processing stars using mono RGB data [Deep Sky] Processing techniques · Chase Davidson · ... · 11 · 499 · 4
Black_Dog_Astrophotography 0.90
Hi everyone, I’ve finally progressed enough in my astrophotography skills to attempt mono rgb stars properly. I have attempted a few targets with rgb stars in the past but I’m just not that happy with them. I’m using my Astro-tech AT 130edt with a .8 reducer, asi2600mm pro, 2’  baader rgb-l filters, auto focuser with the ASIAIR plus. I’ve been having difficulties recently with haloing around stars after stretching, particularly red stars.. My usual technique is:
1. graxpert or dbe
2. blurxterminator
3. noisexxterminator
4. starxterminator
5. Liner fit b&g to red
6. RGB or Lrgb combination
7. arcsinhistogram or ezsoftstretch
8. color masks and curve adjustments
This workflow produces ok star images but I’m looking for perfection. My red stars come out as white stars with red halos.
Are all of these steps necessary or is there an easier process that produces better results? In the image below, I may have had a few imaging subs with red out of focus, which may be why I’m having haloing in the image but this has also occurred in a few other images in the past. Any help or guidance on your own mono rgb star workflow would be really appreciated.
Thanks everyone! CS!
ChuckNovice 8.21
Give this a try for corrected and accurate star colors.
1- RGB combination
2. DBE
3. BlurXTerminator - correct only
4. Image solve
5. (Optional, depending how invasive is the green channel) SCNR - Green
6. Spectrophotometry–based Color Calibration (SPCC)
7- BlurXTerminator - sharpen
8. StarXTerminator
9. NoiseXTerminator
… any other steps you like before stretching …
10. Stretch both L and RGB to non-linear
11. LRGB combination (apply luminance to existing RGB)
12. Rest of your processing
ghatfield 1.51
First, let me say, I think the stars in the above image look good.  I use a similar workflow.  I combine the R, G and B images at the start.  Sometimes I will use linear fit (lowest mean being the standard, usually blue) before combining.  Then…
GraXpert or rarely DBE
Image solver
SPCC (if specific filter is not listed, use one that gives the best linear curves)
BlurXterminator (sometimes use PSFImage script to estimate PSF for image using large preview)
NoiseXterminator (minimum)
StarXterminator or Starnet++
Starless…  very modest arcsinh followed by GHS
Do the same with the luminance or super luminance
Combine stretched L with stretched RGB (statistical means approximately equal)
Stars… very modest arcsinh stretch followed by GHS
Combine nonlinear stars with nonlinear LRGB
Adjust star density with Bill Blanshan's tools if needed (usually method 3)
Photoshop adjustment of exposure, contrast, color intensity, etc (very modest changes)
George Hatfield:
First, let me say, I think the stars in the above image look good.  I use a similar workflow.  I combine the R, G and B images at the start.  Sometimes I will use linear fit (lowest mean being the standard, usually blue) before combining.  Then...
Image solver
Starless...  very modest arcsinh followed by GHS
Stars... very modest arcsinh stretch followed by GHS
Thanks George, I’m looking forward to trying this method out. I’ll post a picture when a get a chance.
AstroDan500 7.19
I would separate stars before any Noise reduction. There is no noise in stars.
ImNewHere 1.20
Try reducing the halo on your stars in Blur Exterminator to a negative number, for instance -10 or -15
Thanks for the advice everyone, I finally had some time to reprocess my M13 data and I really like how the stars came out.
https://www.astrobin.com/5a2ing/
jrista 11.18
Chase Davidson:
If you want to prevent the white core problem, then you need to make sure you are not only not clipping any stars once you stretch....you also need to make sure that the stars are well enough below the saturation point, that they can maintain a color other than white or nearly white. If your image is only stars, this gets easier. As you get into objects, starting even with a glob, although a glob is a good way to practice, this can get tougher.
A simple histogram stretch is probably going to be the most challenging here. Its pretty easy to saturate and clip stars with a simple stretch. There are other algorithms that can help, that will preserve color traits in the brightest signals, while sufficiently boosting the fainter signals. An arcsinh stretch is one example.
Perfect stretching with stars is probably a long shot...you are having to compress a rather immense dynamic range into a much smaller space. So something has to give somewhere. It may be at the upper end (star cores going white), it may be at the lower end (faint details unrevealed), or it might be in the middle, where you can potentially end up with funky brightness transitions and such.
You might have to pick and choose what matters most. In a glob image, I would say, focus on the high end and midtones, and try to maximize quality there. If you stretch the fainter details too much, then that is going to brighten the halos. In fact, you might even decide to just sacrifice the low end, clip the blacks a bit, which might help control some of the halos.
EDIT:
I just looked at the full size zoomed in. It appears that you may have some other image processing that has affected the nature of the stars in the midtones and darker. I would recommend backing off your processing...DON'T do any noise reduction or anything like that, just remove any gradients. Then try to stretch to maximize star quality. You can bring up the black point a bit, even clip the darkest signals a bit, to hide the noise in the background, instead of using a noise reduction algorithm. I think if you do this, it should keep the stars separated (the core stars look a bit wormy right now, and seem connected to each other.) You can then focus on how to maximize your star quality. Once you have star quality figured out, you can then see about bringing up the fainter details, maybe just enough to reveal that little galaxy in the lower right.
Ushavilash 0.00
Please see these approach too it might be help.
Prioritize focusing to minimize halos, try alternatives like Multiscale Linear Transform for noise reduction, experiment with different star mask techniques for better control and Fine-tune color balance during processing for natural star colors and I think you can get some information from https://skyandtelescope.org/
Jon Rista:
Chase Davidson:
EDIT:
* Hi Jon, I took your advice and did a quick reprocessing. I really like doing less with this one and just working on a better stretch. I get some slight haloing that I am still working on. Thoughts?
jrista 11.18
@Chase Davidson FWIW, the halos are there, in the raw data. Processing isn't really the reason why you see them...you see them because processing is just revealing the data.
I think your latest attempt does preserve the stars without clipping, which is what was causing the white cores before.
If you really want to eliminate the halos, there are probably two key things you should do.
1. There is likely an image acquisition issue involved here. Either imaging when seeing is poor, or poor tracking/guiding, or perhaps some optical issue (CA or something lke that) which is leading to the halos in the first place.
2. You may only have a small percentage of your subs that have notably bad halos, in which case if you can identify them and exclude them from your stack, that may help improve the quality of the underlying data.
The only other thing you could probably do, is to use BlurXTerminator to reign in those halos, while the data is still linear. It would not be the most accurate or natural approach, but it could indeed help resolve the problem if nothing else works.
frankz 4.07
Chase Davidson:
1. graxpert or dbe
2. blurxterminator
4. starxterminator
I have an AT130EDT and I recognize what you’re seeing. The HFR of my R subs is always larger than the one of the G subs, which is larger than the one of the B sub. It may be due to some residual chromatic aberration. What I do is to use BlurXTerminator on the R and G integrated masters early in the workflow, while still linear, and tweak the amount of sharpening for each color until the star sizes of the three color masters match visually (taking care of using the same STF for all three after linear fitting them).
I have noticed that doing BlurXTRminator with AI2 on the combined RGB image achieves the same result, but that no longer holds true if I use AI4. Since I prefer to stick with AI4 because of its better performance in other areas, I go through the manual “equalization” process I just described.
Francesco
