HA processing experiment , what do you think ? [Deep Sky] Processing techniques · James · ... · 4 · 406 · 1
jamesmdmad 0.00
Hi all , I was looking for a way to get pure Ha and color stars , so I came up with this after some time , it might be something stupid, but I like the result
I shot LRGB and Ha with a mono camera .
I processed Ha as normal streched,  removed stars and converted to RGB . to that  I added color stars I had  removed from a RGB version  and applied  L  .
 I tweaked the image in curves  then removed stars and reduced them .
here is what I got ,
What do you think , is it any good , is it rubbish, perhaps its a common way of processing , I don't know but i never saw it before
cheers and clear sky  !!
https://astrob.in/94xown/0/
aabosarah 9.31
I really like the result, but don't follow the process. Can you elaborate more on your on how you converted the monocrhome Ha frame to RGB?
jamesmdmad 0.00
Hi , sorry , here I go :
1 Ha mono image , process as normal , remove stars . and convert to RGB, you get an B&W image of Ha
2 add to the B6W RGB Ha the color stars from a normal RGB composition , you get your B6W image with color stars and tainted colour Ha
3 saturate with curves and tweak as you like
4 add Luminance to your image ( I has shot L R G Boo the same image )
5 remove stars , tweak and add stars again
hope that's easier to understand
cheers
James
jamesmdmad 0.00
Just was curious to know if anyone else had tried, I was expecting to get a B&W image with color stars I thoughtcould look nice ;-)
Frank777 7.94
James:
Coincidently,  I was trying the same thing yesterday with a boring RGB image of a Sharpless nebula which looks much more interesting as just a  monochrome Ha image. I didn't go very far with it, but maybe I should try again to get the RGB stars combined with it.
