Reg Pratt:Coolhandjo:
Thanks! so when you say low efficiency was it degrading the overall image?
What I meant was the fact that color cameras can't collect as much light in a given amount of time as mono. The Bayer matrix reduces incoming light for one. Second, each pixel of a color camera is divided into 4 subpixels 1 red, 2 green, 1 blue (RGGB) is the most common configuration. So when collecting light only 25% of the sub pixels are collecting red photos, 50% green, and 25% blue.
With a mono camera there is no Bayer matrix and the entire chip is being used to collect light with a given filter. This means in a given amount of time a mono camera with a red filter collects 75% more light than an osc. Mono with a green filter collects 50% more light. Mono with a blue filter collects 75% more light. So a mono camera can collect more photos in less time than a color camera making them much more efficient.
This is not to say that OSC is bad. Just that it is less efficient. Which is best will depend on the individual, their goals, and their preferences.
Hmm, this is not NECESSARILY true, at least not for all OSC cameras. It entirely depends on the camera, and the nature and design of the CFA. CFA filters are dye based, and they can either be strong, delivering purer color but with lower sensitivity, or they can be a bit weaker, delivering more overlapped color and higher sensitivity. A weaker CFA dye, since usually results in more overlapping (wider bell shaped bandpass), will also be passing more light from a broader band than your average RGB interference filter. Testing has been done that indicates on some of the most popular CMOS cameras, while OSC pixels do transmit a few percent less than the native mono Q.E. curve, because of the overlaps, they often transmit more light than the mono camera using square cutoff filters. Depending on the exact nature of the bayer matrix design, some OSC cameras will pass even more light through the green pixels. Some bayer matrices have a green and a white pixel, or a medium green and a weak green, where the weak passes more light. Even further, because the bandpasses overlap, you are capturing parts of the spectrum in more than just red or green, or just green or blue. You are capturing parts of the spectrum with both sets of pixels. So it is FAR from just as simple as you collect 25% of the light in red and blue, or 50% in green. Its a lot more complex than that.
Between all of these factors, while some OSC might be a little less sensitive than mono, some are actually more sensitive. Further, overlapping bandpasses allow for more accurate color reproduction, as they don't suffer from the metamerism that RGB interference filters do. There is absolutely no guarantee that mono with an interference filter will capture 75% more light than OSC. In fact, depending on the particular LRGB filter set being usd, OSC may very likely in fact pass more signal than the mono+interference filter. The RGB filters for mono cameras, though they may reach nearly 100% transmission, are often fairly narrow. It is not, in fact, strictly the peak transmission that matters. It is the integration of the entire filter area (i.e. area under teh curve) that matters. Compare the areas UNDER the curve for common OSC cameras and common mono filter sets. You might be surprised which wins, despite lower peak transmission. Oh, if you do that, don't forget to apply the CAMERA Q.E. curve to the RGB filter transmission rates...THEN take the area under that curve. You can't have a 100% transmission rate at the pixel, if the pixels efficiency is not 100%. The filter may pas 99%, then the pixel may only be sensitive to 80%, in which case you would really have around a 79% actual rate (this is in fact, accounted for in OSC sensitivity plots already.)
With regards to the bayer matrix and the 25%/50%/25% argument. You can overcome the potential (potential!) limitations of the bayer pattern with sufficient dithering during acquisition, enough frames, and bayer drizzling to integrate, rather than any kind of debayering algorithm. Bayer drizzling will distribute all the source pixel data into EVERY output pixel, this distributing the signal from all channels more evenly. This will eventually negate any impact from the fact that there are only 25% red and blue pixels. It requires more frames (frames, not necessarily more time, which is actually easy enough with modern CMOS sensors since they are so sensitive), but once you stack enough dithered frames with bayer drizzling then you can eliminate this particular handicap of OSC.
SOME OSC cameras may in fact be less efficient. Any of the cameras that use the Panasonic M sensor (i.e. ASI1600, QHY168), probably fall into the "less efficient" category. That is different than saying ALL OSC cameras are less efficient. The IMX183 sensor, for example, is actually highly efficient in general, and the OSC versions achieve only a couple percent loss in Q.E. with the CFA relative to the mono Q.E. curve, and the bandpasses of the CFA channels overlap fairly significantly as well. An OSC IMX183 is actually quite efficient. The 533 seems to peak in efficiency at around 90% Q.E., which is even higher than the IMX183, and seems to sustain higher Q.E. across the visible spectrum. So I would expect that any OSC version of that camera, should be quite efficient indeed.
