I use 2 different setups at the same time, is it possible to combine this sub to one pic ? 1) CDK 14 with QHY 268 Mono 2) Skywatcher Esprit 150 with SBig STF Mono if i combine the subs with CCD Stack it works so i can mix STF frames with QHY frames. In Pixinsight it does not work. I checked 2 pics seperately in PI manually and it also does not work. What is the secret to do this in WBPP. I am sure that this is possible, but i cant find a description or a way to make it work. Does anyone have some input for me ? Thanks for your Help CS Martin |
In PI you can register one (final stacked up light master) against the other and add/average them together. I can't see any issue with that.
Run WBPP normally and then use AlignByCoordinates (masters needs to be solved, this will align & crop all masters to reference image) and integrate/stack them together. If you don't have 3 masters (minimum for integration) you can make 2 copies of each and stack those. Alternatively you can use also PixelMath to add them together (average, sum, …) |
I would combine them in WBPP.
