Any Help With Mosaic Processing? [Deep Sky] Processing techniques · Szijártó Áron · ... · 1 · 212 · 0
Arons.2001
Hello and welcome. I'd like to ask everyone who used or is using Seti astro software if it can be standalone or built into other software.
Does anyone have any luck with Seti Astro? I am trying to process the mosaic stacked image that my seastar made. I'm clueless about how I can process all of the Mosaic frames from the subfolder in Siril. I found and have the preprocessing script for it, but I can't understand yet how it works cause they somehow fail.
And I am trying to find a way how to do that differently. Recently, I have been to the Seti Astro standalone software when I try to do something with it. It starts to run something, then closes on me. Is this software still working, or is it broken? Cause I can't discern why the heck it's closing on me. Has anyone tried to use this software anyhow?
Is there a possible way to process an image with it?
However, I'm still trying to find a possible way to pre-process those frames in Siril. So I may need some help or suggestions if anyone has had any luck with this case.
pterodattilo 0.00
I made a couple of Mosaics using PixInsight, if you need help, you can send me the stacks of the single panels and I'll try to combine them for you.
