Nearly 14 hours, L: 7 hours and RGB: 6 hours.
Camera: ASI 294mm
Workflow separately for L and then RGB
1) PixSingit
- Color Combination for RGB
- BlurXTerminator for RGB and L
- DBE (separately for L and RGB)
- SPCC for RGB
- GHS for L and then RGB
2) Photoshop
- Camera Raw Filter, Noise reduction (color) and then NoiseXTerminator (just a little) for L and RGB
- StarXterminator for L and RGB stars
- Separately adjust colors for stars and nebula with Match Color, Selective Color, Hue & Saturation; little adjustment with Curves.
- "Darkening" the stars layer (Linear dodge) with adjustment layer (Curves) for L and RGB
- High Pass filter (then Soft Light) + blur mask for the center if the Iris.
- Merge layers
- NoiseXTerminator
- Color Blotch Reduction Action
- Enhance DSO and Reduce Stars (opacity about 30%)
- Some final adjustments for colors (Match Color, Selective color)
I'm not sure about colors of the stars and colors of the dust around Iris... what are your fist feelings about the photo?
I will be grateful for any comments and suggestions for improving the processing and image.
LRGB stack master frames after calibration if anyone would like to try to process the image: https://drive.google.com/drive/folders/13vI0ygI1-kjfV2JhqtRmhykvikqBMKNC?usp=sharing
Photo details on Astrobin: https://www.astrobin.com/xsbhet/C/
