M13
I posted the raw stacked master and flat and bias here: https://drive.google.com/drive/folders/1R5M8IVMYzyVe4VETdQfP5lW2Da6eFlLd?usp=sharing
My first attempt at imaging M13 in Bortle 7 skies and I can’t seem to eliminate the background aberrations in PII. The image posted was done with DBE and some IC. ![]() M13 I posted the raw stacked master and flat and bias here: https://drive.google.com/drive/folders/1R5M8IVMYzyVe4VETdQfP5lW2Da6eFlLd?usp=sharing |
I'm not sure what you mean by "background aberrations" but I'll assume you mean aberrations tout-court. First, I shall not the poor tracking the resulted in the elongated (in the RA direction) stars. Secondly, you also have tilting (quite possibly) and back-spacing issues (The nexus should have 90.3mm backfocus from the back-end of the camera thread) that needs being dealt width, witness the field aberrations which should have been suppressed at that image scale.
Thanks all for your help.
Looks like a good start. Looks like you have vignetting. Did you use flats to calibrate? Mike |
George, You image is really good. I was worried I didn’t have good subs. Thanks, Glenn |
Elmiko: I used flats and bias frames to calibrate. I think my flats are a bit off and will have to redo. Glenn |
Shoot your flats at 25000 ADU's.
