[RCC] M51 first time using H-alpha (data linked) Requests for constructive critique · Johannes Maximilian Möslein · ... · 12 · 442 · 4
Joo_Astro 3.80
Hi everyone,
I took this image of M51 and was using an Ha filter for the first time:
I added the Ha using Pixelmath as explained in this video
Overall I would have liked to get more data, but the weather has been absolutely horrible the last few months, so I was just able to get about 4 hours.
Now I'm looking for advice, mostly on editing and adding the Ha. You can try editing the data yourself if you want to: https://drive.google.com/drive/folders/1TPAaZLsmIRYVJB036HIYWTW4HUTlXpVa?usp=share_link
Thank you,
Johannes
Joo_Astro 3.80
Anyone?
WhooptieDo 10.40
I'm not sure who that guy is, but he literally tells you to mask 90% of the photo and then add in the Ha.      You shouldn't mask when you add data.  Might as well just not use Ha if you're going to do that.   I stopped watching after that.
Try this:
https://www.nightphotons.com/guides/advanced-narrowband-combination
You should consider continuum subtraction for a much more accurate image.    Also, as expected it looks like the Ha falls off rather quickly in your image, with nothing in the dimmer parts of the spiral.  Maybe change the color of your Ha a bit, it feels pink.
Anyways, try the guide, no masking required.  I've been using this for over a year now.
ghatfield 1.51
I've tried several methods for adding Ha to RGB, and I have found this one to be the most straightforward.
https://www.youtube.com/watch?v=LwuiS8N1A-E
It does involve red continuum subtraction.   This is a trial and-error process, but after a while, you will get a feel for the right factor to use.  Avoid too much black (clipping) in the subtracted Ha.  Sometimes using a mask to keep the addition away from the background is worthwhile.   If you like this method it is easy to create two pixelmath expressions to save as processes.
Overall, I like your image.  The colors are good.  Good detail and it does not look overprocessed.
George
Joo_Astro 3.80
Thank you, I will try those methods.
Johannes
HegAstro 14.24
I second the use of the method linked by Brian Puhl.
You will need to remove the stars before doing the H-alpha addition to avoid artifacts in the stars. At least I have found that to be the case, although Hagen claims it is not needed.
WhooptieDo 10.40
Arun H:
StarX and Starnet will remove smaller Ha structures like in galaxies.  Highly recommend not doing that.   The any artifacting in the stars will 95% of the time get covered with your broadband stars.
This is not a complete image, only a WIP, but this is like 3 hours of RGB with my 36+ hours of Ha. (I just wanted to see the structures) Absolutely no StarX or Starnet was performed in the Ha layer.
StarX would have eaten all the little structures in the bands of M106
HegAstro 14.24
I ended up getting saturated cores that stood out if I didn't remove broadband stars. What am I doing wrong?
WhooptieDo 10.40
Arun H:
Did you remove the stars from the broadband image before adding the continuum subtracted Ha?
The broadband stars go on top of the narrowband stars
HegAstro 14.24
Brian Puhl:
Yes. Essentially I had to combine two starless images and then add back the broadband stars. If I didn't remove the broadband stars prior to addition, I would get saturated cores that stood out.
WhooptieDo 10.40
Arun H:
Brian Puhl:
Hmm. I think I'm (were) just getting confused here.
You do need to remove broadband stars, at least as far as I know.  You don't need to remove narrowband stars.
That being said, for bright targets that don't have small structures (like those found in galaxies) I will do starless prior to continuum subtraction.    It's all about preserving the details. StarX can be destructive if not used carefully.   Bright nebula and such you don't risk losing data.
My generic flow:
Create starless RGB image
Combine HRR to perform continuum subtraction.
Curve, denoise, and (almost) clip NB signal.
Use pixelmath to re-add Ha NB.   Perform multiple times if needed to boost the signal/structure.
Add RGB stars on top.
That's exactly what took place in the example above.   The RGB data is weak in that tho, so don't read deep into it.   It was purely what I had that I could share.
Joo_Astro 3.80
Just as a quick update, this is what I got using continuum subtraction:
It already looks way better, now I just need to practice and collect more data. Thanks to everyone who answered.
Johannes
aabosarah 9.31
Brian Puhl:
Arun H:
Thanks for that link. You already have an incredible image there.
