[RCC] First try on the double cluster Requests for constructive critique · Konrad Krebs · ... · 4 · 114 · 2
Konrad_Krebs 0.90
Hello everyone,
as I often follow posts here, I wanted to take the opportunity to start a post myself.
This is my very first time for an open star cluster. Taken with OSC and UV/IR cut filter.
Pixinsight:
Stack & align with WBPP (1x drizzle, seperate channels)
Crop
DBE
BlurrX correct only
Image solver
SPCC
NoiseX
GHS
Curves
Color saturation
Bill Blanshan's Star Reduction script (Transfer method, stretch 0.45)
Export as Tiff
Photoshop:
Remove green cast
Minor color adjustment
Minor brightness adjustment
Export to JPEG
Personally, I'm still a little bothered by the color of the stars and that some of the stars have a slight magenta edge. I also think that the stars don't really pop yet.
How long are your subs?
Konrad_Krebs 0.90
I usually take 30s each, living under bortle 6.
Ok, that's pretty short which is want you want. That said, you could go even shorter like 15 or 10 sec.
I think my main take on it as an image is that the double cluster, which is the main subject is being obscured by the wide field and vast numbers of faint stars. If it where me, I'd crop in and see if I could find a way to reduce the number of fainter stars so that the cluster has more of an identity if that makes sense. You might also try a more aggressive uv/ir filter that cuts a little bit deeper in the blue. Something like a fringe killer type filter might help with the bright star halos.
bigCatAstro 0.00
Konrad Krebs:
Hello everyone,
Pixinsight:
Crop
DBE
BlurrX correct only
Image solver
SPCC
NoiseX
GHS
Curves
Color saturation
Export as Tiff
Photoshop:
Remove green cast
Export to JPEG
I don’t know much about the OTA you’re using, however; you could substitute the SVBONY UV/IR cut filter with a fringe reducer filter. That should help with reducing chromatic aberration.
There are several options, including one from SVBONY (marketed as a color corrector). I think it works fairly well, but I’ve since moved over to the Baader version of the filter.
