CameraTilt_ASTAP_FLT91_ASI294MCPro
Help determining what I have in the way of tilt. ![]() CameraTilt_ASTAP_FLT91_ASI294MCPro |
Did you try to analyse with NINA Hocus Focus plugin to verify the ASTAP measurement? (if not, you should ...) I recommend this thread on CN: https://www.cloudynights.com/topic/809050-tilt-discussion-astap/ It has all you need to know about tilt. CS, John P.S.: Yes, 300s is far too long. Try 30s or less with L filter. |
Did you try to analyse with NINA Hocus Focus plugin to verify the ASTAP measurement? (if not, you should ...) Good read! I'll be ordering an adjuster and fine tuning mine. With NINA, I don't see a way to load a file other than to load an Auto Focus session. Anyway, I have a much better understanding of tilt thanks to the thread. Appreciate the guidance. |
