Do you think this is a reflection nebula? Requests for constructive critique · Vlad Sazhen · ... · 17 · 741 · 2
astrochumak 0.00
Hi all,
Recently I stumbled upon a yet undocumented reflection nebula. As you can see from the attached photo, the star (the position of which is marked with a red circle) illuminates a part of the documented dark nebula. CDS Portal recognizes the dark nebula but does not show any hints of the reflection nebula.  All the papers connected with the dark nebula do not mention anything about the reflection nebula either. That being said, would you consider this as a discovery of the reflection nebula?
Thanks,
Vlad
You might be able to find it here https://aladin.cds.unistra.fr/AladinLite/
Press the "stack" button and the triangle arrow button and change the stretch to the necessary setting (you can try sqrt)
astrochumak 0.00
Yes, it is visible on Aladin, that was one of the first things I checked. However, this nebula was not documented anywhere.
skybob727 6.67
Am I missing some information hear. No color makes it hard to tell, for now, it just looks like an Ha or lum image to me.
astrochumak 0.00
Bob Lockwood:
Yes, sorry I forgot to mention the details. This is a blue channel. This nebula is weak in all other channels.
astrochumak 0.00
Here is a rough view of noisy data. I will be collecting more light as the weather allows. Don't take the shape for granted for now because this was heavily stretched and denoised with noisexterminator.
Vlad Sazhen:
Since that's the case, and it's very visible in the blue channel, I think it's a new discovery.
Die_Launische_Diva 11.54
You are missing the most important information, probably due to your excitement smile! Where is the object located?
astrochumak 0.00
Die Launische Diva:
You are missing the most important information, probably due to your excitement ! Where is the object located?
The object is located not too far away from several confirmed reflection nebulae.
The other reflection nebulae were documented, and I assume because 1) some of them are brighter, 2) they are connected to stars that were of interest for research. The star that illuminates this potential ref neb isn't well covered in papers, so I presume it's not that interesting to astronomers, at least now.
ShelbyCouper 0.00
We need the location of the closest reflection nebulae to this.
astrochumak 0.00
I will share more once I gather more data, but so far everything points to it being a ref neb.
ShelbyCouper 0.00
I would like to try my hand at capturing this also. I’ve been focusing mostly on Cepheus and Cygnus lately with some Cassiopeia thrown in for fun. What is the FL you are using at the moment?
astrochumak 0.00
This is a pretty dim nebula. In fact, because it is so dim I rented a remote scope to get some good data of it which I will later be combining with the data from my scope. Once I receive the remote data and if it turns out to be a reflection nebula, I will make a public announcement with all the info
However, to get the idea of its brightness, you can try capturing the Hummingbird nebula that Nico Carver discovered or the reflection nebula in the dark shark nebula.
skybob727 6.67
If you wanted to keep this a secret, why'd you bring it up in the first place. Yes it's blue, a reflection nebula most likely.
Why not let us little guys see if we can see it on are own. You won't even post it with stars to give it's location away.
@Vlad Sazhen  I recommend not telling any person the coordinates until you publish your whole finished RGB image, including the data you get from the remote telescope, with stars, then we could figure out if it is new or not.
The other guys can wait a little. It is all about patience.
astrochumak 0.00
Bob Lockwood:
Because my original question was whether a reflection that wasn't documented before and is a part of the known dark nebula can be considered a new discovery. Now that I heard people's opinions, including the ones outside of the discussion here, I'm heavily leaning to it being so.
Thanks! Yes, I will post a full image with stars once I make a public announcement.
astrochumak 0.00
https://www.astrobin.com/79mxas/
